What Map Do You Think Is Our Strongest...?
Old Mar 24, 2004 | 09:33 AM
Jonesi's Avatar
I think Death Trap is our best map.. Silver and Ted are deadly with the shotguns.. We are all good at Mining.. The Steves get to snipe and even Phil is good with the RPG on that map.. And Smitty likes the RPG also.. I think overall this is our strongest map..
Old Mar 24, 2004 | 10:34 AM
ferizzo's Avatar
still a Masshole
Yeah because we know it well as a terrorist or seal. this map we can really do as either one.
Old Mar 24, 2004 | 01:37 PM
soopa's Avatar
The Creator
Ya ferizzo said it right. That is the one map that is heavily in favor of one side... but we play well as BOTH sides.
It compares to Enowapi in difficultness as a seal, if not harder... yet we play it 100X better than Enowapi.
Old Mar 24, 2004 | 01:38 PM
soopa's Avatar
The Creator
I think Silver+Ted are our best Terrorists. They have patience.
I am super impatient... I don't play well as a terrorist.
Old Mar 24, 2004 | 02:03 PM
Jonesi's Avatar
Old Mar 24, 2004 | 02:19 PM
mrsteve's Avatar
I agree, last night was awesome with them in the basement of Enowapi. I don't think Silver saw more than one guy. HAHA Ted cleaned them up.
A good SEAL strategy on ENOWAPI is to breech both doors at the exact same time. You can get to the ramp door 1st, wait like 10 seconds for the someone to get to the bridge gate, then count down 3-2-1. Also while this is going on, call the air strike a few seconds prior to placing C4. All 3 entrances will open within a matter of seconds and if equal amounts of people rush in each door at the same time it is pretty easy to clean up the upper level of the map.
The basement is where it gets tricky.
Old Mar 24, 2004 | 02:25 PM
Jonesi's Avatar
Where it gets tricky is when there's mines by the bridge and turret, in that area.. And also if they are on the middle ramp.. It can throw a whole game plan like this right out the window..
Edit: Not to mention while they try and blow up the mines it makes them easy targets for both snipers and grenaders.. Or they run through them and lose some men like last night..
Old Mar 24, 2004 | 05:41 PM
mrsteve's bro's Avatar
i think if there one guy left in the basement you should distract the ramp and have a guy come in through the ladder
Old Mar 25, 2004 | 10:07 AM
soopa's Avatar
The Creator
yep.
if theres one guy u just keep them busy at both ends.
Old Mar 25, 2004 | 01:17 PM
Jonesi's Avatar
To all noobs.. When you go down the ladder. First throw a grenade down to rid of mines at the bottom of the ladder.. 2nd-if they blew out the lights, pull out your pistol(preferably sd).. When you get down there use the night vision and look for more mines.. If possible I usually crawl on the ground so they can't see me. And while you are on the ground you can plant the bomb. Piece of cake.. I used this method yesterday and it worked perfectly..
Old Mar 25, 2004 | 01:37 PM
soopa's Avatar
The Creator
Thank you Capt. Obvious!!!
Old Mar 25, 2004 | 01:44 PM
soopa's Avatar
The Creator
too build on jonesi's point tho...
when you throw that grenade down the ladder.... make sure you get off the wooden platform... get out in the grass... or on the other side of the shed or whatever the fuck it is.
cuz the grenade blast comes through the floor.
Old Mar 25, 2004 | 01:55 PM
Jonesi's Avatar
I was stating that for the "noobs" not to mention most people don't know the pistol gives you night vision on that map.. Also when you crawl on the ground it most likely will bypass their night vision b/c most people aren't staring on the ground..
Old Mar 25, 2004 | 03:47 PM
soopa's Avatar
The Creator
i know. i was kidding.
Old Mar 25, 2004 | 05:34 PM
its hard to see mines with night vision the best way is to get a sniper with thermal to see
cycdaniel
Dec 17, 2019 10:58 AM
soupi
14
Nov 15, 2015 11:15 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
iesu3423
Oct 6, 2015 06:54 PM
