Quick Vista and OS question...
Old Feb 19, 2008 | 02:55 PM
stangg172004's Avatar
_____ like a rabbit
my computer just crapped out on me and i cant find the restore CD. Is it possible to use the upgrade version of vista to reinstall the OS or do i need to buy the full version? thanks
Old Feb 19, 2008 | 03:13 PM
bz268's Avatar
Because Of You
What computer do you have? Last time I called Dell for the CD, they just mailed the whole package to me free of charge... Fedex 2nd Day shipping...
Old Feb 19, 2008 | 03:15 PM
_____ like a rabbit
wow, i have an xps but the warranty just ran out a few weeks ago. Would they still send one out?
Old Feb 19, 2008 | 03:19 PM
Whiskers's Avatar
Go Giants
There used to be a "bug" that let you do it...
Old Feb 19, 2008 | 03:28 PM
_____ like a rabbit
^was that a haha tease or is there an elaboration coming?
Old Feb 19, 2008 | 03:32 PM
Whiskers's Avatar
Go Giants
http://www.google.co.uk/search?hl=en...+cd+fresh&meta=
Old Feb 19, 2008 | 04:19 PM
_____ like a rabbit
a small detail, my computers OS is completely gone to shit. It says something to the effect of "Windows cannot load. Missing necessary file C:/windows/system32/system" thats not verbatim but it was something like that. Would i still be able to boot using the Vista upgrade CD? and how about if its student licensed version? I can get a copy for $99 through my university...
_____ like a rabbit
oh and thanks for the help!
Old Feb 19, 2008 | 04:22 PM
Whiskers's Avatar
Go Giants
You may be able to replace / repair that file using safe mode or console....
Put the CD in and boot...
Old Feb 19, 2008 | 04:27 PM
_____ like a rabbit
CD is MIA per my original post thought if im going to pay Dell to get another recovery CD, i might as well just go all out and get vista already. Ive been reading the links you posted and it seems like you can upgrade on a blank HD, does that mean i can install on a HD w/ a corrupted OS on it?
Old Feb 19, 2008 | 04:29 PM
_____ like a rabbit
oh an ive tried booting in safe mode but it wont even give me that option when i click F12...
Whiskers's Avatar
Go Giants
I meant to put in the Vista upgrade CD....
Old Feb 19, 2008 | 04:30 PM
_____ like a rabbit
oh ok, im gonna look into the student dicount deal through my school. Thanks for the help whiskers!
Whiskers's Avatar
Go Giants
F8....
Old Feb 19, 2008 | 04:33 PM
_____ like a rabbit
damn it! ok, ill give it a try tonight. thanks again...
Old Feb 19, 2008 | 04:37 PM
Billiam's Avatar
Big Block go VROOOM!
FYI - I think the Vista upgrade CD is still going to ask you to insert a valid XP CD to verify you're eligible for upgrading. In theory pointing the Vista upgrade at the corrupted XP OS that's on your drive might work, but leaving that corrupted OS there and running the Vista upgrade on the same drive doesn't really sound like a good idea to me.
Old Feb 19, 2008 | 04:42 PM
_____ like a rabbit
so reformat the drive then?
Old Feb 19, 2008 | 05:07 PM
Billiam's Avatar
If what I posted is correct (don't put too much faith in my memory), then you're in a catch-22. You'd ideally want to reformat the drive to get a cleaner Vista install off of the Vista upgrade CD, but the Vista upgrade CD may in turn ask you for a copy of XP to verify your upgrade eligibility. In that case you're SOL because you've now formatted your drive and don't have an XP CD.
In case you're wondering, Microsoft's boilerplate answer for this situation would probably be for you to purchase your Vista upgrade from your computer manufacturer.
Old Feb 19, 2008 | 07:52 PM
Beelzebub's Avatar
There is a way to do it
Microsoft internal documentation reveals workaround for Vista Upgrade DVDs with no need for a previous version of Windows
DailyTech reported on Monday that Microsoft no longer performs disc checks during an operating system install. In the past, when performing a clean install, a user could boot from an install CD and insert a disc from a previous version of Windows for upgrade compliance.
However, per Microsoft's new licensing requirements for Vista, users are required to install a Windows Vista Upgrade from within Windows XP. When this occurs, the Windows XP license is forfeited and the Windows Vista installation process can take place.
DailyTech has confirmed a new workaround proposed by Paul Thurrott (via Microsoft internal documents).
This workaround allows users to perform a “clean install.” The process is a bit tedious, but is not hard at all to complete. Users have to perform these simple steps to perform a clean install of Vista without a previous version of Windows installed with an upgrade DVD:
1. Boot from the Windows Vista Upgrade DVD and start the setup program.
2. When prompted to enter your product key, DO NOT enter it. Click "Next" and proceed with setup. This will install Windows Vista as a 30-day trial.
3. When prompted, select the edition of Vista which you have purchased and continue with setup.
4. Once setup has been completed and you have been brought to the desktop for the first time, run the install program from within Windows Vista.
5. This time, type in your product key when prompted.
6. When asked whether to perform an Upgrade or Custom (advanced) install, choose Custom (advanced) to perform a clean install of Vista. Yes, this means that you will have to install Vista for a second time.
7. Once setup has completed for the second time, you should be able to activate Windows Vista normally. You can also delete the Windows.old directory which contains information from the first Vista install.
There's no telling why Microsoft left this loophole wide open with Windows Vista Upgrade DVDs, but this means that any retail upgrade DVD can be used as a fully functioning full retail copy of Vista.
http://www.dailytech.com/article.aspx?newsid=5932
Old Feb 27, 2008 | 12:09 PM
_____ like a rabbit
update for those who care, i got it to work using the link beelzebub and whiskers provided. No problems so far but i wish it came with plugins like flash, shockwave, java, adobe reader etc etc. Its amazing how useless the internet is with out them but its a quick 20 minute fix. My only gripe is that it is impossible to use or install any questionably attained software; had to buy office 07 Anyways, thanks for help gents!
Old Feb 27, 2008 | 12:11 PM
Whiskers's Avatar
Go Giants
Openorg is free....
Old Mar 1, 2008 | 11:45 AM
Beelzebub's Avatar
No problem
If I had to pay for any MS product, I would have probably gone with Openoffice.org.
MilanoRedDashR
Oct 8, 2015 10:30 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
TLguy42
Sep 26, 2015 11:27 AM
