networking Q
Old Mar 7, 2007 | 02:04 AM
RJANACONDA's Avatar
Registered TL Lover
Question networking Q
is there something i can change/buy so that my desktop computer doesent have to be on and loggin in with a admin for other computers/devices on my home network to accsess the web
Old Mar 7, 2007 | 03:26 AM
Kikaida's Avatar
Ummm... a router? You can buy one practically anywhere that sells electronics... CompUSA, Best Buy, Walmart, etc.
You can buy a Wireless Router with 4 port switch (most common configuration sold) for $30 - $100.
You need a high speed connection of some kind, like DSL or Cable for this to work. If not, there ARE devices that you can use, but harder to find.
Old Mar 7, 2007 | 03:30 AM
Kikaida's Avatar
From another thread:
Originally Posted by RJANACONDA
yea i had to turn it off and back on 3 times to get it complet the other night i think it was loosing the conection during the update my house is full of concrete walls and i dont get a good signal to it is there anything i can do to boost my wirless signal? also i got on acurazine with the internet browser i logged in but after the successfull log in screen it redirected me back but i wasnt logged in is that normal i know its just a test version
Hey, waitaminute! I am confused...
Old Mar 8, 2007 | 01:30 AM
RJANACONDA's Avatar
Registered TL Lover
i have a wireless router but in order for say my wifes laptop to get online or my wii the desktop has to be on and logged in as admin (win xp pro) my set up is like this i have 1 desktop that is connected to the modem/wireless router via ethernet port and wifes laptop connects via built in wirless adapter and so does the wii. in this regard it seems the other devices actually connect to the desktop and use the descktop connection to get to the router or the desktop has to be on the give the pasword to my isp
Old Mar 8, 2007 | 09:28 AM
Pete1burn's Avatar
You are using internet connection sharing, or ICS. Your desktop is sharing the internet connection to the other computers on your network. UGH.
Disable ICS and just run a normal connection through the gateway (being your router). Simple to set up. Just make sure your router is set up for a DHCP connection, with your username and password for your ISP in the setup, then it should push that signal to your other computers through wireless. No need for any computer to be on for others to access the web.
Old Mar 8, 2007 | 11:52 AM
RJANACONDA's Avatar
Registered TL Lover
Pete i dont see how i can do this looked all over the settings on my raouter manager and dont see any of the things you talked about
Old Mar 8, 2007 | 01:14 PM
Pete1burn's Avatar
ICS doesn't work through your router, it works through your computer. Look through your desktop. Check the My Network Connections and stuff. You'll find it.
Old Mar 8, 2007 | 02:01 PM
Kikaida's Avatar
I have a few questions:
1) What kind of internet connection are you using? (DSL, Cable, Wireless, FiOS, Dial-up, etc)
2) Who is the provider
3) Does your provider require you to use an application on your computer to login with a username password to get access?
4) What brand / model is your modem?
Old Mar 9, 2007 | 10:19 AM
RJANACONDA's Avatar
Registered TL Lover
i found it in the routers management program i had the dhcp enabled but i didnt check the box that allowed remote access to the internet so the problem is solved but i never would have found it with out your post pete. rep points for u
kikaida
1 ADSL (dont ask me what the differance is between it and dsl cuz i dont know)
2 ALICE (italian)
3 i use plain old internet explorer
4 im using a us robotics ADSL/Wirless gateway
Old Mar 9, 2007 | 11:53 AM
Kikaida's Avatar
Glad you resolved your problem!
Old Mar 12, 2007 | 07:52 AM
Pete1burn's Avatar
Glad you fixed it, even if it wasn't what I said.
Feb 25, 2020 09:57 AM
Sep 17, 2015 10:16 AM
IndycarFaster
Sep 11, 2015 02:52 PM
