Anyone upgrade to Vista?
Several threads elsewhere. Just search. Personally, I give it a big fat
BTW - M$ announced that upgrade versions of Vista will require you to have a previous Window OS actually installed on the PC. You will not be able to use a Vista upgrade to do a clean install.
Originally Posted by whynot
umm... isn't that what an upgrade usually means?
I believe that in the past as long as you had the old OS CD you could do a fresh install.
ie, format --> begin install of Vista upgrade --> You are asked for previous OS CD ---> Verifies --> Then continues with Vista install.
That sucks if true.
That sucks if true.
That sucks if true.
Im waiting till i build me new system this spring to add vista (and for the first few service packs)
I just cant get myself to buy a mac, id like to but i dont have the $$ or the time to relearn
Now if you want to wipe your machine for a rebuild you're looking at:
format -> completely install XP -> install Vista upgrade
Originally Posted by Yumchah
Awesome!
I'd posrep you, Anil...but, I can't give you any until I spread more posreps around.
screw that! give me my rep points!
That sucks if true.
That sucks if true.
I've installed this at work on a test machine to dick around with it, but I'm not touching my home system anytime soon...
Co-worker went out and bought Ultimate upgrade. He heard about a way around having to have a previous OS installed.
- He formatted.
- Began Vista install.
- Was asked to enter product Key, but he denied.
- Install continues.
- Vista automatically puts you into a 30 day trial install.
- Once he was up and running he reran the Vista install by putting the CD back in. Entered the Vista product key and all was fine.
No previous OS CD or key even needed. Apparently MS knows about this workaround and is working on a fix, or so he says.
- He formatted.
Workaround Discovered For "Clean Install" With Vista Upgrade DVDs
- He formatted.
- He formatted.
http://www.dailytech.com/article.aspx?newsid=5932
Screenshots available at the link above.
DailyTech reported on Monday that Microsoft no longer performs disc checks during an operating system install. In the past, when performing a clean install, a user could boot from an install CD and insert a disc from a previous version of Windows for upgrade compliance.
However, per Microsoft's new licensing requirements for Vista, users are required to install a Windows Vista Upgrade from within Windows XP. When this occurs, the Windows XP license is forfeited and the Windows Vista installation process can take place.
DailyTech has confirmed a new workaround proposed by Paul Thurrott (via Microsoft internal documents).
This workaround allows users to perform a “clean install.” The process is a bit tedious, but is not hard at all to complete. Users have to perform these simple steps to perform a clean install of Vista without a previous version of Windows installed with an upgrade DVD:
- Boot from the Windows Vista Upgrade DVD and start the setup program.
- When prompted to enter your product key, DO NOT enter it. Click "Next" and proceed with setup. This will install Windows Vista as a 30-day trial.
- When prompted, select the edition of Vista which you have purchased and continue with setup.
- Once setup has been completed and you have been brought to the desktop for the first time, run the install program from within Windows Vista.
- This time, type in your product key when prompted.
- When asked whether to perform an Upgrade or Custom (advanced) install, choose Custom (advanced) to perform a clean install of Vista. Yes, this means that you will have to install Vista for a second time.
- Once setup has completed for the second time, you should be able to activate Windows Vista normally. You can also delete the Windows.old directory which contains information from the first Vista install.
Originally Posted by Sly Raskal
I'd buy an oem version anyway which is cheaper than the retail versions out there so doesn't matter to me.
OEM software is also tied to the motherboard it is first installed on. Unlike the retail versions of Windows which can be transferred to a new computer, OEM versions are not transferable. What about upgrading hardware? Microsoft says that anything is fair game, except the motherboard. Replacing the motherboard in a computer results in a "new personal computer," which the company considers to be synonymous with a transfer. It's not permitted with an OEM edition of Windows.
Nevertheless, I've known users who got around this limitation by calling Microsoft and reporting that their motherboards died when they wanted to build a new computer. It is Microsoft's policy to allow motherboard swaps in instances where a system is defective or has suffered a hardware failure. But you shouldn't bank on this approach; there's no guarantee it will work and, well, liars don't get ice cream. Also, while retail versions of Vista include both 32-bit and 64-bit versions of Windows, OEM versions are specific. You get one or the other. This follows from the per device restriction. The end result is that OEM versions may not be that attractive to users who frequently build new computers from the ground up.
I was all set on up grading, actually paying money for it, but found out today, that I'm entitle to a free up grade cause I just bought my tablet earlier this month...
that would suck having to buy a new copy every damn time you build a computer.
you buy it, you own it, you should have the right to put it on any machine you want as long as you aren't violating their policy of having two installs using the ssame serial code.
And that's where M$ gets most people. In their world, OS's have always been licensed per device not per user. You sell or give away a computer and the OS license goes with it.
there are too many flaws with their stance.
