Working a 20v jap engine into my ae86 corolla!! *PICS*
@ slide or die @
Since this is not a toyota forum i post here instead...i just wanna share with my fellow a-zine ppl what i've been doing with a rwd corolla i found for $100...before you flame i have modded 99TL punk!
Engine/car specs:
ae101 4AGE "silvertop" engine (jap fwd engine)
160hp/162trq, revs to 8400rpm!!
Car is a 1986 "Ae86" rwd Corolla ---> i'll be drifting with it
This has a month in a lil unused "shop" filled with lots of shit. Working force= Me, 2 friends and my beloved mechanic who does the hard stuff 'cuase we're all 18 and younger.
The car will run in a week or two...still need mad underdash wiring work and who knows what else will come up. Waterlines are already finished but dont show in pics..i'm using an ae82 radiator so one of the hoses run ontop of the headers (not there yet) and the otherone from under close to the strut tower!! fuel lines/walbro pump = ok, tranny/20v = OK...wateva look at the pics!
1Pic = 1000words...this first two are worth 3000 a peace!!
This is the solution to ALL POWER STEERING PROBLEMS...by me btw...THANKS!!
the secret is removing the 20v A/C and putting a nut under the tensioner pulley screw so you change the direction of the tension
Original ae101 fusebox already connected/wired to harness!!
For all those interested i sell full 20v engine sets for a Co in cali...are his engines:
Engine/car specs:
@ slide or die @
Dont worry about cut firewall or the mess, everything's being done as its supposed to with some custumicing from our part...i'm so pumped
btw the car weights ~ 1400lbs right now...if not less!
5sp manual on 13" rubber
I spent ~ $1100 for the engine and most of the req swap parts (btw i sell these engines sets) and i'm expecting another $500-$800 on an electrician (already started working) but the labor is done by my crew = free
i got $1200cash offers for the car with the old engine which ran on 2/4cylinders...expecting it to be worth about $4000-5000 'cause of all the body/engine/frame/rust work i've done...maybe more
Originally Posted by ryder1650
so how much money on top of the $100 are you spending?
Received 2,776 Likes
Initial D!!!
01 3.2 CL-s
curious.. ive never really read to much on swaps with the ae86 but i know there is alot out there and the car is very fun to drive..
what car did this engine your swapping in orinally come from? and is this a common swap? and specs on the engine would be nice also..
@ slide or die @
INITIAL D
Not a common swap, came from a 1997 jap corolla "Ae101". My model it came with a 4ac engine (70hp @ crank) and it ran on 2 our of 4cylinders!! (there's a 112hp twin cam model = GTS)
Swapping for a silvertop or blacktop is like doing a 3.5conversion to a TL-p
20v 4AG-E "Silvertop" vs "Blacktop" --> (5valves per cylinder)
160hp/162trq vs 165/160trq
Redline: 8400rpm vs 9400!!!
Runs on Air Flow meter vs MAP (sidedrafted carbs)
notice how this engine has 4x ~ 40mm throttle bodies...sounds beautifull!
*researched 32mpg city 40mpg hw
Stock weight ~ 1600lbs
i have an urge to drive it again!
Originally Posted by etxxz
i'm very sure it'll stay there, explain to me why you're saying that?
@ slide or die @
o i see...that's must've been why my mech told me not to make it too tight. there's no way i can use the pulley any other way and i couln't find a belt to run crank-p.s directly...and even if someone makes the belt, how would i put it in?
I'm going there tomorow to finish some stuff...*i'll take pic requests*
Check out this Ae86 drifting clips:
http://145.53.214.64/Filmpjes%20AE86/
watch "Ae86 drifting madly" and "Superdrift"
*Right click and "Save as"!!
rockyboy
01-25-2016 06:00 PM
sockr1
10-01-2015 01:31 AM
