We have a 5 speed Odyssey in the shop
It came in slipping really badly and we're just about to open it up. This is a 2003 Ody with a BYBA transmission. The tranny is very similar to the 2000+ TL tranny. It's huge compared to the older 4 speed tranny.
I'm very interested to see the setup inside. We're opening it now...
Here are the codes pulled from the computer:
P0730 Incorrect gear ratio
P1750 Mechanical fault in hydraulic system
Drivability symptoms:
Flaring on 1-2 shift
Slipping in all gears
Delay on 3-4 shift
No lockup
No kickdown
No downshift when coming to a stop
It was low 3 quarts of fluid (that is A LOT) - filling it made no difference.
It showed no signs of leakage - but we're checking into that further. Hell - where'd the 3 quarts go?!?
Delay on 3-4 shift
No lockup
No kickdown
115k on the ODO
Flaring means that the car temporarily falls out of gear while shifting - so on this tranny the 1-2 shift feels a little like 1->N->2.
The third gear clutch pack is wiped out. I'll have more once the inspection is completed.
my parents 01 odyssey is in the shop right now. already had to get the transmission repaired 4 times and this time, it just stopped working. if you put it into drive or reverse and step on the gas, it doesnt move.
the car is the biggest POS.
Bet the 3rd gear clutch packs and drum look just like the 2 i have laying at home from my trannies Take some pics. Did the spring start spinning in the bottom of the drum maring it up too??
Stator force? The stator is part of the pump. All automatics and CVTs use hydraulics.
It turns out that this units primary problem was being low 3 quarts of fluid. I don't know how it got that way - but it was - and all five clutch packs were burnt up. It turns out 3rd was no worse than the other 4. There were no overheat conditions on any other part of the tranny (i.e. 2nd gear).
It needed a master build kit (all clutches and steels) and 5 solenoids (from dealer $$$). It's being built now.
Did we warranty it? No - I'm not Honda
The dealer had quoted hom 4-5k - they weren't going to warranty it either. He's leaving here with a bill for 2.8k.
Sorry - didn't think to take pics and it's just about back together now.
Anyone with a TL 5 speed comes it, I'm definitely taking pics!
The dealer had quoted hom 4-5k - they weren't going to warranty it either. He's leaving here with a bill for 2.8k.Sorry - didn't think to take pics and it's just about back together now.
When my tranny went, I had to skip 3rd sometimes because the engine revved without the tranny engaging.
And when I got my car back, the new tranny decided to quietly slip out of 1st often when the car was stopped and idling. I would proceed to go and got nothing but revs. So I had to send it back in again.
I take it back. My builder had cleaned the parts and loaded the clutch packs, but had not begun assembling the tranny. I took pics and will post them tonight. You'll see what I'm talking about with the 3rd gear clutch pack. It's not in the same location as the other 4... way out on the end of it's shaft
I will never get a trans rebuilt for a honda again. I had a 98 accord where they could not rebuild it properly and refused to admit a problem. less than 5 K mile later they rebuilt it again stating that they put the wrong parts in. less than 5 K later it was having problems again. rebuild again... less than 2 K later again trans dead.
OK - here are some pics. I just got the reassembly pics. He had already done the inspection and cleaning.
Here are the infamous clutchpacks
From left to right :
First and second (double drum)
Fourth and fifth (double drum)
Third
This is the differential ring gear and the infamous filter that can't be replaced
This is the underside of the van
This is the frame that has to be removed
Here is his new torque converter
Here is his flex plate - this engine had ZERO oil leaks. I love Honda engines!
Miscellaneous gears for the shafts and valve body parts
This is the main valve body component
Here is the inside of the tranny prior to case half installation
This is the case half that covers the internals
This is the other case half showing where the pump and valve body are installed
Here is the lonely 3rd gear clutch pack on the end of the countershaft
Here is the unit finally assembled
MANY little brackets, wire harnesses, and hydraulic lines on the outside.
Third
Originally Posted by SodaLuvr
Did the kit contain updated friction materials, or should I say, what updates were avaliable?
Did you re-use the external oil jet or was the integrated oil jet used?
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Sep 17, 2015 09:01 PM
CaliAtenza
5G TLX Photograph Gallery
Sep 9, 2015 06:48 PM
