VID - Supercharged E46 M3
Old May 14, 2004 | 05:46 PM
Chaptorial's Avatar
To do this you'll first actually need an E46 M3 of course.
The E46 M3's S54 motor was inspired by design along the lines of the typical BMW Motorsport engines that pre seeded it. With multiple throttles to increase volumetric efficiency and high RPM thresholds to facilitate breathing, the traditional "raspy" exhaust is inherent in the nature of the beast. It is truly a wonderful work of engineering at it's best, and is also one of the few motors in the world that can produce more than 100 HP per liter of displacement.
AA Tuning has spent many hours researching how we could improve on this by way of forced induction and at the same time meet the following criteria:
1. Maintain the stock engine configuration without opening the engine.
2. Make it a true bolt on system that is available in "kit" form, whereby most all parts are "plug and play".
3. Add 100 more HP at the flywheel without any "excessive damaging" stress on the engine.
4. Do all this at an even lower engine speed to further increase reliability of the engine and the supercharger, which will decrease heat and friction on all moving parts as well.
5. Be able to run pump fuel with as low a fuel as 91 octane.
6. Do all this with the lowest boost level as possible.
7. Be gentle on the driveline.
8. Maintain the same "M Style" powerband, and at the same time enhance it.
9. Keep it affordably priced.
10. Be able to fit all versions around the world. (except CSL at this time)
We achieved these goals by using the Rotrex C38 supercharger, which gives the motor a gentle 5.5psi air-to-air intercooled push. The result is an astonishing 32-35% increase in power at a lower RPM limit of 7600 RPM vs 8000 RPM from the stock configuration. This just goes to show how well a heavy breathing motor like the M3's responds so wonderfully to a gentle bit of forced induction.
The system can be installed in approximately 10-14 hours and is easily reversible back to stock in less than one day.
And this is only at the base 5.5psi level of boost. Just imagine the possibilities.
VIDEO
Old May 14, 2004 | 06:47 PM
bkknight369's Avatar
365 hp? what does a stock m3 get at the wheel? isnt it above 300? doesn't sound like a 100 hp gain to me...
Old May 14, 2004 | 07:46 PM
Zapata's Avatar
Cost Drivers!!!!
Chap,
nice find!
why not a turbo setup would've increased the trq a bit more as well. NOt a fan of the centerfugial blowers on anything but v8s.
Old May 14, 2004 | 07:47 PM
Crazy Bimmer's Avatar
Stock M3 puts about 275-280HP and 230-240 LBS/FT Torque to the rear wheels
Old May 14, 2004 | 07:48 PM
srika's Avatar
Moderator Alumnus
365hp at the wheels = 427hp at the flywheel, figuring a 17% drivetrain loss.. that is just about 100 more hp than stock
Old May 14, 2004 | 07:56 PM
pimpscls's Avatar
THE SILVER BULLET
that is a dream car, but i never seen a T/C on the e46, that would be even better.
Ive seen the video b4 on bimmerforums, the owner got it a few months back
Old May 14, 2004 | 08:01 PM
mattg's Avatar
some pics i took last year.
Old May 14, 2004 | 08:05 PM
Zapata's Avatar
Cost Drivers!!!!
worst video evar.....
Old May 14, 2004 | 08:07 PM
pimpscls's Avatar
THE SILVER BULLET
mattg that is very nice, where'd you take em
Old May 14, 2004 | 08:09 PM
mattg's Avatar
import drags last year at woodburn, oregon.
Old May 14, 2004 | 08:21 PM
goldmemberer's Avatar
goldmemberererer
Holy moly
That's some crazy shit, I didn't think an engine that has such high output for its displacement already could have a "cheap & reliable" F/I application.
The M3 tranny causes about an 18% loss from the crank to rear wheels, (stock dyno) The HP number is real nice, about 110 hp over stock, but the torque, much like the stock M3, leaves a lot to be desired. There's only a 40 lb/ft or 15% increase in torque with the S/C, so if a (reliable) turbo could be made, that would rock ass.
Of course, I didn't expect the torque to improve by much, 3.2 liters can only develop so much.
Old May 14, 2004 | 09:09 PM
Zapata's Avatar
Cost Drivers!!!!
Re: Holy moly
yea but see that's the problem with centerfugal blowers. A turbo would be perfect.
YuppieCL's Avatar
Moderator Alumnus
in love w that car.
Old May 14, 2004 | 09:43 PM
goldmemberererer
Re: Re: Holy moly
Not that I know much about turbos, but isn't it the same case with the CL? A turbo could be made to yield more power, but in the end be less reliable?
Old May 14, 2004 | 09:54 PM
Zapata's Avatar
Cost Drivers!!!!
Re: Re: Re: Holy moly
nah absolutely not. Turbo's can get peaky if boost pressure isn't watched carefully but the same can happen with a SC.
Old May 14, 2004 | 11:04 PM
scalbert's Avatar
Re: Holy moly
3.2L can develop more torque than that. I made more with less added to the engine. The presented vehicle did not just have the SC installed. That plenum is not stock nor do I expect the outlet flow to be stock.
First thing though, I would trade my CL-S6SC for that M3 any day. I sometimes wish I had taken my wife's E46 328i and worked it over. The E46 M3 is just so much grander...
This is not meant to take away from that car as it is extremely impressive. I just want to harp on how well the J32A2 is and if mated to a worthy chassis would probably be more acknowledged.
That M3 was making 5.5 PSI of intercooled boost and made that power. A blown J32A2 at the same boost will make nearly the same, if not more, torque but cannot rev as high to produce the same power numbers. It will come up about 40 WHP short.
I have no questions that with the IC the J32A2 would make nearly the same power, at lower revs, while making noticeably more torque. I suspect that 300 lb/ft and 350 WHP would be realized once intercooled. And you can easily run a little more boost to get even more power. This will be seen in the next coming weeks once the new pulley is in.
The problem is that the chassis paired to the J32A2 is not up to par to put down that power making the production worthless. The M3, on the other hand, can utilize the power much greater making it a better power platform irrelevant of the significantly greater handling capability.
Old May 14, 2004 | 11:18 PM
scalbert's Avatar
Originally posted by mattg
Am I imagining things but does the SC outlet go right into the plenum?? If so, why is there an unused FMIC??
Old May 15, 2004 | 12:17 AM
goldmemberererer
Re: Re: Holy moly
Oh god yes, I agree with everything you said. In terms of chasis and drivetrain, the CL is nothing compared to the M3. When it comes to engine, though, the CL can hang with the best. And Acura obviously knows that, the TL's still using the J32... I really don't know how much better the chasis is.
The upcoming AWD TL sounds good, though.
Back to the M3:
Old May 15, 2004 | 09:27 AM
Type S Lady's Avatar
I feel sick! That red Bimmer makes me drool.
Old May 15, 2004 | 06:11 PM
darrinb's Avatar
///M POWER
wow that car is def hot
i have never seen a f/i m3 before
Old May 15, 2004 | 06:26 PM
Chaptorial's Avatar
No arguments here but that's the only one they got. :P
Old May 15, 2004 | 07:27 PM
Zapata's Avatar
Cost Drivers!!!!
no worries
M3 exhaust sounds like a fart passing through a tin can and how much can you put up with the dude saying WOOOOOHOOOOO, OMG, WHOOOOOOOOHOOOOOOOOO....Life is good......douche
Old May 16, 2004 | 03:40 AM
yi_yi's Avatar
lolololol
Old May 16, 2004 | 07:46 AM
Ray Khan's Avatar
haha.....good eye
Old May 16, 2004 | 07:59 AM
dallison's Avatar
registered pw
the rims on the red m3 are hot
Old May 17, 2004 | 10:05 AM
Chaptorial's Avatar
Bump for the Monday crew.
Old May 17, 2004 | 10:07 AM
bigman's Avatar
'Big Daddy Diggler'
good looking
Old May 17, 2004 | 08:09 PM
red6speed's Avatar
I've seen WAY worse videos, at leat that one is long enough to see the car's performance, even though they didnt get it on the outside in motion
IBankMouse
Jun 13, 2020 12:53 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
k6biv
Sep 22, 2015 02:06 PM
Chief F1 Fan
Motorsports News
Sep 21, 2015 09:39 AM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
