Rsx
Old Feb 25, 2004 | 09:12 AM
slo-down2.2's Avatar
Rsx
I'm getting a new car this spring, and I need something under 20k but I also want something fast and nice. My options so far are Jetta GLI (6 spd 15 deg. 6cyl) Sentra spec-v, and Lexus IS. I'd rather stay away from the Lexy b/c you know how expensive those things can get. Just recently I noticed that the RSX could be an option. The question is if I go with the Acura, should I go w/ the standard 2.0 and boost, or just go with the type-s and run low 14's?
Old Feb 25, 2004 | 09:35 AM
spdy0001's Avatar
I now drive an accord....
Base and type-S are both 2.0 engines, and you will probably not run low 14's with the "s", but low 15's are obtainable. True you can boost the base model, and that is the only way I would ever own one because they are slow stock
Old Feb 25, 2004 | 09:42 AM
I know that stock the type-s can't run low 14's, but I'm sure I can get it down there with no power adder....don't you think?
Old Feb 25, 2004 | 09:54 AM
spdy0001's Avatar
With bolt on's like intake exhaust, probably not. If you get hondata to reflash the ecu and maybe upgrede the top end of the motor to accpet a 9K redline you might get there. Oh course you would also have to deal with traction problems, which will kill your 1/4 mile time.
Old Feb 25, 2004 | 12:16 PM
anothercls's Avatar
cooperS with upgraded supercharger, relocate the tach and be happy, get it used.
Old Feb 25, 2004 | 12:46 PM
I will never drive a Cooper...not a slam, but my frekan' mom likes those cars
Old Feb 25, 2004 | 01:45 PM
Lex300's Avatar
You WILL get into the low-14's with a Hondata flash, Hondata IM gasket, good intake. You will not need to touch the head. No need for more agressive cams or higher redline. With the addition of a good header/exhaust combo 13.90's are not far off. The K20 motor is a VERY capable motor and with the right bolt-on's and a little tuning it will surprise you!
A good friend of mine went 14.80 with a bone-stock '03 with about 1,000 miles on the ODO
Old Feb 25, 2004 | 01:50 PM
gregshin's Avatar
NISMO pwnz j00!
get SRT4 nuff said...
Old Feb 25, 2004 | 02:11 PM
fuzzy02CLS's Avatar
cycdaniel
Dec 17, 2019 10:58 AM
Jul 16, 2017 07:33 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
