rockstar143's 2013 CTS-V SUV Wagon Thread - GM Owner & Cut Springs
#3521
Sure thing, man...
there's a drop down where you can select OEM for $146...or NOT oem for $60 (down from almost $70)...non oem is slightly lighter but it's fine and I like the contrast.
If I am going to hit stuff here and there, I'd rather just buy the cheap one anyway...
Thanks for the suggestion Jason, but even at a discount that'll b $300-350 I think...I'm trying to keep it simple and not spend more.
rockauto, obviously...
#3522
ah.. rockauto..
#3525
Received 7,772 Likes
#3526
rockstar143 (02-13-2017)
#3528
The following 2 users liked this post by Majofo:
Predatorbird (02-12-2017),
#3529
I can tell you.. fitment is on point!
#3530
Looks great!
#3531
Super cute we bought new wheels the same day! What are the odds? I drove about an hour to get them in this cali rain. I wish people didnt wait until it rained to get new tires. My god.
rockstar143 (02-12-2017)
#3532
The following 4 users liked this post by Majofo:
#3533
Been using that product what's on the VIP tray, it would seem.
#3534
#3535
#3536
I'm just here for the lols
#3537
you dick!
YASSSS, I love when you don't take yourself too seriously, Jonathan!
and no sir, they are cast for sure...heavy! but not too heavy in comparison to stocks...plus with this car, you don't feel it.
I just needed a cheap easy solution to get me off a cracked rim...this solved that problem and looks good in the process so I'm stoked.
and again, for a hail mary, no research blindly trusting Joe's research...fitment worked out beautifully. Again, very appreciative for the help.
The following 3 users liked this post by rockstar143:
#3538
you dick!
#3539
double post and double pic
#3540
based god
#3542
also.. nice battleship, paint canoe battleship grey
#3543
#3545
Received 3,860 Likes
Wheels look awesome. Rear fitment is spot on. From those pics looks like you could use a slight spacer on the fronts though.
#3546
#3547
It's supposed to be tucked mang.. because race car
#3548
#3549
Funny, I thought about it, but I'm fine with how it is...what I might do is see about correcting the front camber a little if it's designed like the rear to end up with factory spec alignment.
Also, my tpms is not synced up since I bought new ones so i'll need to go by Acura again anyway.
#3550
Is Acura your plug? btw.. do you guys know if a generic tire wand will sync the TPMS?
I'm going to replace mine when I swap the tires out. Wondering if I should just grab a wand.
#3552
#3553
Also on Vowners:
TPMS re-set
1. turn the key on but DO NOT start the car.
2. Hold both the lock and unlock on the remote wait for the the horn to sound it will now be in the learn mode should pop up in info center
3. start at the l/f (l/f park light will be lit)...let a bit of pressure out (10 secs) wait for horn
4. move to r/f (r/f park light wil be lit) ... let a bit of pressure out wait for horn
5. move to r/r (r/r park light wil be lit) ... let a bit of pressure out wait for horn
6. move to l/r (l/r park light wil be lit) ... let a bit of pressure out wait for horn
..then turn the key off should be
#3554
Some say it doesn't work.. I say, let out pressure slowly.
If not, let it out fast.
Should work..
Should work..
#3555
Heres the copy pasta from tpms forum.. it's not standard ignition, it's also not push to start..
GM-8
With standard ignition:
1. Turn the ignition to the ON position (engine off)
2. Using keyless entry system: press and hold lock and unlock button simultaneously until horn sound and release INFO button until TIRE LEARN message is indicated on display. Hold down SET/RESET button until horn sounds. LF turn signal is illuminated to indicate learn mode enabled.
3. Starting with LF tire, increase/decrease the pressure until horn sounds.
4. After horn sounds, proceed as in step 3 for the next 3 sensors in the following order, RF RR LR.
5. After LR sensor has been learned, turn ignition to OFF position. Adjust all tires to pressure listed on tire placard.
With Push-Button start:
1. Press and hold the push start button until the vehicle is in accessory mode. Note: on Cadillac models you will know you are in accessory mode when the Cadillac emblem appears on the DIC.
2. Press the MENU button located on the turn signal lever until “VEHICLE INFORMATION MENU” is displayed.
3. Once you are in the VEHICLE INFORMATION MENU, use the arrows on the signal lever until the DIC displays the vehicle’s tire inflation pressures and positions.
4. Press and hold the button located on the end of the turn signal lever until “ Are you sure that you want to relearn? YES or NO” is displayed.
5. Use the arrows on the signal lever to highlight YES. Once YES is highlighted, press the button located on the end of the turn signal lever. The horn will chirp, “Tire Learning Active” will be displayed on the DIC, and the left turn signal will be illuminated.
6. Beginning with the left front tire, use a TPMS activation tool to activate the LF sensor. Once the sensor has been activated, the horn will chirp and the right turn signal will be illuminated. Repeat procedure in the following order. RF, RR, LR. Once the LR has been activated, the horn will chirp twice. You can then turn the vehicle off to exit “learn mode”.
#3556
according to tpmsforumzzz, can inflate too to do the learn.. should be cake.. HONK!
#3560
It was expensive to get a tool for my Lexus but I bought a tool for the GM sensors for like $60.
