resistors
Old Apr 18, 2009 | 03:17 PM
SpeakandBeFree's Avatar
resistors
does it matter if the resistor wire is on the inside or on the outside of the resistor?
Old Apr 20, 2009 | 08:34 PM
synth19's Avatar
resistor for what?
Old Apr 20, 2009 | 09:42 PM
Fishy's Avatar
Not just a smell
Are you continuing on from this?
Originally Posted by SpeakandBeFree
how am i suppose to know which resistor to buy, and can i still install them in the back even though im only changing my front turn signals?
I believe in Darwinism, but... to be nice, I'd suggest getting a full kit or a professional install instead of picking resistors out of a parts bin. There's a lot to consider and you don't want to overheat and burn a resistor around gasoline.
Old Apr 21, 2009 | 07:04 AM
mrmako's Avatar
Someday, an RS6 Avant+
The reason for a resistor is to drop voltage across it, so the other end has a lower voltage. If you are replacing one, be sure the colors are exactly the same. Do not get a higher ohm rated resistor, as you will have issues. Also, the last color, the tolerance is important. Don't say silver is like gold and that's OK. It's not. it's a percentage, and you don't want to screw that up.
So what exactly are you doing and what wire are you talking about?
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Greengecko
Sep 16, 2015 08:19 PM
gaping46and2
Mar 25, 2015 10:26 AM
enigmaos
Nov 7, 2007 12:12 PM
DerrickM
Feb 5, 2005 12:20 AM
