The Official Honda S2000 Thread
#3482
As far as not driving the S2000 anymore - that was definitely a consideration before I put the lift in, but it should work out really nicely in the winter when I never drive the S2000 anyway. My 2004 S2000 that I bought with 1500 miles on it in the spring of 2004 has only 24k miles on it - so I don't drive it a lot to begin with
Before I got the lift, if I wanted to drive the S2000, I would have to park my car on the street so I could get the S2000 out of the garage... in this case, if I left the GS on the street or on the other side of the driveway, I could then lower the S2000 and pull it out. I only drive the S2000 when I can put the top down, so it wouldn't be on rainy days so leaving the GS outside is not such a big deal ... We'll see how often I drive it over the course of the next year I guess
rockstar143 (08-15-2014)
#3483
I had the light corrosion issue as well, and fixed it by vigorously moving the switch back and forth for a minute. hasnt come back in 3 years
#3484
But if you only want to lift the car for suspension/brake work - a 2-post lift is probably a better choice.
Undying Dreams (08-15-2014)
#3491
I know I've seen them in person. but most run 17's around here..
when I was buying wheels recently.. I thought to myself.. my accord had 18's, and they (almost) looked big on my accord... and it was a much larger car.
i see some that look nice in pictures though... jtrix yours doesn't look bad at all.
i think with them being a darker color it takes the focus off how large they are for me.
#3492
mine are 17 x 9 and 38.5/40.5 pounds with tires F/R...super light.
my 18x9 on the TL are 41.5 all around (square tire setup).
I don't mind how they look on the car, but I do agree that 17's are right for this car. I actually have two sets of aftermarket wheels that aren't even +1" from the oem wheels I have stacked in the garage (aspec for TL and AP2V2).
#3494
I wouldn't take offense, I know you're defending the use of an 18" wheel, they do look great and weigh about the same or less than a smaller one. I think his point is for this car and for it's main purpose, he'd prefer to have light and a smaller diameter wheel.
Trust me, the reason I knew I wanted the Advan on the S is because I test fit my TL ones but 18's and mainly the +29 offset was just toooooo beefy for the front fenders.
Your car looks great, man.
What are you selling? Wheels or the car itself?
#3495
Not offended one bit. I have multiple sets of wheels. I am just confused at how "rotation size" is not subjective and would like an explanation.
17" tire gets a higher sidewall profile than an 18". Most of my wheels weigh less than the tires wrapped around them.
Rolling diameter remains equal, so long as you're using the appropriate sidewall profile tire.
Thanks, those are old photos. The car is essentially an AP1.5 - everything good from an AP2 on MY00. I am selling the Advans. Would sell the car if someone really wanted it and made an offer as well, though. Lol
jtrix21 (08-15-2014)
#3500
#3502
i don't want to write an essay explaining but remember it is your axle that moves your wheels, and tires are attached on to the wheels.
There are too many variables: tire size, tire weight, tire pressure, wheel weight, wheel diameter, gear ratio and etc...that will impact the result but
When 2 identical cars with the same overall wheel/tire height and weight. One is 18 and 1 is 17". 17" one will always accelerate faster. Simple Physics.
Difference is usually not that noticeable but for s2000, it is.
Some quick Google search:
http://www.physicsforums.com/showthread.php?t=184311
https://van.physics.illinois.edu/qa/listing.php?id=326
#3505
Sorry but I have to disagree.
If both wheel and tire combinations have the same weight but one is 18" wheel and the other is 17" wheel, it'll require the same amount of torque to rotate the package.
A ton of bricks or a ton of feathers is still a ton.
You can't dispute that, but perhaps your opinion is formed on your experience of having an 18" wheel/tire combo that is heavier in total than your preferred 17"
Anyway...
On wheeler dealers.
Anyway...
On wheeler dealers.
#3507
Anyway...
On wheeler dealers.
Anyway...
On wheeler dealers.
So what all of this means is say you have motor that can deliver 10 in-lb of torque. If you attach a wheel to that motor that has a diameter of 1 inch the force on the outside edge of that wheel will produce 20 lb of force since you would divide the motors torque by the wheels radius. Now if you increase the wheels diameter to 2 inches the force produced at the circumference of the wheel will be 10 lb.
The following 2 users liked this post by mr5parkle:
Ken1997TL (08-15-2014),
#3508
No, you change gearing when you change wheel/tire package diameter, which is why we were debating weight.
My other post specified that my particular 18" wheel weighs less than the OEM 17" wheel. If you go +1 you generally go down 10% in aspect ratio to make up for it. This lighter package (unsprung weight) will allow for faster accel, decel, and lateral.
I understand that diameter is always variable, though, between tire pressures and even tire brand. Without having custom wheels/tires made it's always gonna have too many variables.
Just because Nitto makes a 225 tire doesn't mean it's the exact identical size as a falken 225, etc.
Which is why, endgame, I wanted an explanation. Obviously if the overall diameter was increased, it will rotate less times at the same speed, vice versa, but he said it's not subjective and it really is. He felt his car was sluggish with 18 over a 17, and I simply am here to say it's not solely because of the +1 sizing.
#3510
My point is he prefers 17 over 18 probably because whatever 18 setup he tried had either a taller final gear effect or weighed more than his 17 setup. It's not exactly the +1 in wheel diameter to blame, as in many cases (mine) you can be +1 and have less unsprung weight with little-to-no gear change.
It's personal preference to a point (aka subjective) and the point stops when you take my examples into consideration:
Same identical rolling diameter and weight. One with 17" wheel and one with 18" wheel = no difference in work needed (torque)
But anyway...
#3511
sooooo ummm I found a set of 4 tires with only 3000 miles on them.. but they are squared sidewall heights.
I notice, even with aftermarket wheels, most people stick with the +1 size sidewall up front... will there be any negative effects/drawbacks of running a 40 up front and in the rear?
#3512
more clearance for your fender, slightly harsher ride...do it.
I got your point, bud...I was agreeiong with you. I just prefer that a larger part of my diameter be tire, is all. More comfortable and more grip.
#3513
This "may" lower your ride height 5mm and "may" give you 5mm more tire-fender clearance.
Sure, doesn't sound like anything to scoff at, but it's still fact.
So be mindful that the 40 is in direct relation to the number before it.
*edited for the "may" because if you have a stretched sidewall (wheel wider than your tire) any height difference you did have is effected. Make sense? Same if you have a wide tire on a not so wide wheel, your sidewall profile is effected. The above remains true for using the same wheel in both instances, keeping into account the fact that not all tire brands make tires equally. The falken Azenis is an example.
#3515
yes, I know its smaller than OEM, and shorter in height.
just seeing if there was any direct road effects such as vibrations from that height difference..
my overall height is different from oem anyways as im on coilovers. but my front/rear ratio is the same as it was stock.
weirder/smaller changes in cars have caused strange driving feelz
appreciate the info.
#3518
You'll be fine...I often wondered if the car would look and sit better if I had uniform sidewall all around. Lower rear sidewall generally results in sunken ass syndrome to get the perfect wheel in arch ratio when adjusting the coils otherwise.
#3519
jtrix, first off, I'm another 3G/S2000 owner so
2nd, wtf, being as low as you are, the TE37 I had were literally +48 7.5" and 225/40 front and fuck my life they gnarled my fenders.
Come to think of it, I'm a moron...I added 10MM spacers and that was when I had an issue. Whoops...plus, driver fender had bondo work I was unaware of so it didn't roll well, and ended up having slightly less clearance than driver side. Plus, my fat ass in the car didn't help.
#3520
Lol the last picture is deceiving - action shot on a hard right around some cones. That was with skunk2 lowering springs and Oem shocks as well. I've torn the push clips for the inner fenders over time, but that's because I drive the car like it's not lowered at all - in comparison to other vehicles I have/had.
These AP2 V1s have 235/40s on the rear and 215/50 front LOL.
