New JDM Civic Type R faster than NSX Type S Zero
You'll Never Walk Alone
I was just watching the July 2007 version of Best Motoring Video. The drift king, Keiichi Tsuchiya, was test driving the new JDM Civic Type R around Suzuka, and he managed to achieve a lap time of 2:35.20.
For comparison, here are the lap times of the fastest JDM machines:
Civic Type R: 2:35.20
NSX-S-Zero: 2:35.44
Lan Evo VI RS: 2:36.50
RX-7 RS: 2:35.81
R34 GTR V-spec: 2:39.56
Here is a link to a screenshot of the above times:
http://www.xanga.com/tl_type_s
Here are some details about the new Civic Type R.
HP: 225ps
Weight: 1270kg (same as NSX Type R, or 10kg lighter than NSX Type S Zero)
Basically, the Type R is a hotter version of the Civic Si/Acura CSX Type S.
NSX-S-Zero: 2:35.44
RX-7 RS: 2:35.81
HP: 225ps
So what makes it faster than the last gen Integra-R? K20A engine, 1190kg, LSD, etc ...
(http://www.honda.co.jp/auto-lineup/i...ata/index.html)
By the way, the new civic is also faster than the DC5 Type R in a 1/4mile race by about 0.2s.
.................................... [shibitsuku] TYPE R ... [integura] TYPE R (DC5)
Redline ......................... 8,400rpm ................ 8,400rpm
Power .......................... 225PS /8,000rpm ...... 220PS /8,000rpm
Torque ......................... 21.9kg m /6,100rpm .. 21.0kg m /7,000rpm
Power per liter .............. 112.5PS ................. 110PS
VTEC changeover .......... 5,800rpm ............... 6,000rpm
Bore x stroke ................ 86.0×86.0mm ......... 86.0×86.0mm
Displacement ................ 1,998cm3 .............. 1,998cm3
Compression ratio ......... 11.7 ...................... 11.5
Sparkplug Heat range .... 7th iridium .............. 7th iridium
Throttle bore diameter ... 64mm ................... 62mm
Intake manifold ............. Single tube short circuit Single tube short circuit
Air intake diameter ........ 75mm ................... 70mm
Exhaust pipe diameter ... 54mm ................... 54mm
The transaxle has shorter 1-3 gears and higher 4-6 gears compared to the DC5. It wears wider 225 tires on 18 inch rims as opposed to the 215 tires on 17 inch rims for the Integra. Everything was engineered to minimize air resistance in the engine. The header collectors merge alot more smoothly.
Originally Posted by bigman
Ithink the suspension setup of this car is what puts it ahead of the ITR by a few 10ths. But as stated above, those few 10ths can easily be gained back by driver error.
rockyboy
01-25-2016 06:00 PM
mugen_kid
11-13-2015 10:38 PM
Iakonafuji
09-21-2015 02:39 PM
