Mixing Oil?
Mixing Oil?
Is it safe to mix synthetic oils like Royal purple and German Castrol together and leave them in there? They of course would be the same weight of oil. Also if mixing oils, is there anything specific that you should watch out for?
I don't think it matters that much. People at www.bobistheoilguy.com do this all the time making special 'cocktails': 2 quarts Mobil 1 with 3 quarts GTX etc. Synthetic Blends are a mixture of synthetic and dino oil conveniently packaged and those are mixtures. As long as you stick to the original viscosity range you'll be good.
One on the right for me
I had one customer who would always bring in his own oil when I would do his oil changes, 5 qts, all different viscosity - ranging from 530 to 1540. Fucker was a little off. Went into a piece of shit Trooper.
S E L L
In the Mid-South meow
why would you want to do that? some oils have different additive packages that don't jive well together, or so I've heard.
Someday, an RS6 Avant+
Seems to me that, in a pinch, you could dump something other than the brand into your car without any ill effects. Meaning, you realize you're a quart low and can't get to a place that sells your exotic, Kazhakistan synthetic blend with rare linseed or some BS.
Then if there are some additives that may not be compatible with each other, you just do an oil change and put in your favorite. No big deal. I don't think there's a benefit to 4 quarts of .99 cent Wal-Mart and 1 quart of $1,000 Super Royal Blue Ball Supreme
![J/K](https://acurazine.com/forums/images/smilies/jk.gif)
Received 1,080 Likes
http://www.valvoline.com/carcare/art...cid=2&scccid=2
Usage
Now, while the companies don't recommend mixing or switching back and forth, one company's synthetics are fully compatible with others and compatible with conventional oils. The source of compatibility problems was high levels of ester in the earlier synthetics. Considering the consequences, it's best to verify this compatibility, either on the company's website or with your trusted mechanic.
Usage
We have a car that burns a quart of oil every 2k, and we have the dealer plan for oil changes every 15K. The oil is the 15K one, but they don't cover top offs. They charge 8 dollars for the oil, and I was thinking, why pay 8 dollars for some ok oil when you can get something better for a few dollars more and just mix it it.
F1 cart racer
if the car is burning an quart of oil every 2K something is not right with it. i know there is some loss, but the max i have seen was on nissans and infiniti's running a VQ.
im curious, what kind or car is it and how many miles?
BMW with big engine?
In the S6 it burns about a quart every 2-3k. I don't like Audi's oil change intervals so I do it more frequently. Motherfucker takes 12 quarts though.
S E L L
![what](https://acurazine.com/forums/images/smilies/what.gif)
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Evil Mazda Driver
German cars burn oil, British cars leak it. When I worked for the local Audi dealer 99% of the top-offs I did for oil were on turbocharged cars, mostly the 1.8 and 2.0 turbo four banger motors. Audi considers it normal to burn through one quart between changes.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
if your burning a quart every 2k you got rings going. tear it down, new bearings, new rings, depending on what the pistons look like maybe new. maybe new rods.
IBankMouse
06-13-2020 12:53 PM
