Lower car
Old Nov 5, 2021 | 10:38 AM
1963racecar's Avatar
5th Gear
Lower car
I installed megan racing coilovers and my car make some vibration or shaking, 0 to 25 when turning or go straight I change the 4 tie rod and alignment and still can't someone tell if have the same problem and to fix is not really to low right now is half inch over the tire thanks
Old Nov 5, 2021 | 11:36 AM
ttribe's Avatar
Year, make and model of car?
Old Nov 5, 2021 | 12:16 PM
Chief F1 Fan's Avatar
OP's post makes my head hurt
Old Nov 5, 2021 | 12:37 PM
5th Gear
toyota camry se 2014
Old Nov 5, 2021 | 05:26 PM
any particular reason you'd believe you can get help for a Toyota on an Acura site?
Old Nov 5, 2021 | 07:16 PM
TylerT's Avatar
Turd Polisher
Could be a lot of things - Make sure lugs are torqued to spec, wheel balance is good, etc - also, could mean control arms or other suspension components are worn out and aren’t taking the lower ride height very well.
Otherwise, a Toyota forum would have a better idea.
EDIT - could be axles, too. Worn out CV joints don’t take well to lower ride height either.
Old Nov 5, 2021 | 08:34 PM
5th Gear
Shake
The inner tie rod and tie rod end are new axles both right and left are new too everything started when I lower the car but is one inch over the tire maybe I should go up one inch to see what happen and go alignment I really don't know and here in ocala every mechanic say change this or that already over 280 and the shake at liw speed still there and only happen 0 to 20
Old Nov 5, 2021 | 08:52 PM
TylerT's Avatar
Turd Polisher
In my experience, new axles doesn’t mean no vibrations - remanufactured axles are hit and miss .. unless you purchased brand new OEMs.
Just food for thought.
Old Nov 5, 2021 | 09:32 PM
5th Gear
Shake
Ok,but original from toyota dealers cost 480 each plus tax my new axle are from napa and say too the manager bring to me the best axle in the market behind toyota branch but remember everything started when I installed megan racing coilovers before that was okay
DC93
Nov 5, 2021 08:41 PM
Umirza84
4G TL Problems & Fixes
15
Jun 22, 2019 11:18 PM
myst0ryman
Nov 15, 2017 01:50 PM
viebotls
Aug 17, 2013 08:41 PM
