Insurance Question
Old Jan 16, 2010 | 04:35 PM
Whiskers's Avatar
Go Giants
Insurance Question
My wife and I have continuously driven into our house (our garage is at a bad angle). We probably have about 2K worth of damage each on our cars in various locations of the cars (mostly quarter panels). Will our insurance cover the repairs, or should we just let it be?
Old Jan 16, 2010 | 04:47 PM
LuvMyTSX's Avatar
I wouldn't get insurance involved.
Old Jan 16, 2010 | 05:03 PM
Whiskers's Avatar
Go Giants
If I don't, then Im not getting it fixed...
Old Jan 16, 2010 | 05:05 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Well, from the insurance company's perspective, it was your wife's and your fault that you damaged your cars, hence they mostly likely would not cover that. It was not an accident, so no claim will be made. Even if you asked, I doubt they would cover it. I would pay for the repairs out of pocket. :twocents:
Old Jan 16, 2010 | 05:20 PM
Whiskers's Avatar
Go Giants
It was obviously our fault.
Old Jan 16, 2010 | 06:27 PM
Will Y.'s Avatar
Registered but harmless
:shakehead
Striking the wall accidentally is a result of negligence which will be covered by insurance, unless Whiskers and wife are intentionally driving their cars into the wall to damage the cars or house. Fault is irrelevant to coverage.
However, Whiskers should pick the most recent date(s) when the cars hit the wall if he makes a claim-- most policies have a reporting requirement (often 30 days from the incident date) to get coverage.
If Whiskers & spouse wait for more than the XX days under the policy to report an incident, the insurer can deny the claim.
Old Jan 16, 2010 | 06:35 PM
teranfon's Avatar
Moderator Alumnus
I'm sorry Whiskers, I just find this funny. What do you mean continuously?
Is there no way you can modify your garage? Or parking?
Terry
Old Jan 16, 2010 | 06:44 PM
LuvMyTSX's Avatar
Get the cars fixed, then put some padding on the walls
Old Jan 16, 2010 | 07:05 PM
Whiskers's Avatar
Go Giants
Originally Posted by Will Y.
:shakehead
Good info..I may need to make up the date though...
Terry
Well, not continuously like I backed out and in again, but over the course of a year....The only change I can make is to take out the two double door garages and make it one big door. But even so, not sure if that would help since I have polls in between...
Old Jan 16, 2010 | 07:06 PM
Whiskers's Avatar
Go Giants
The padding would need to go outside the house....
I need draw a diagram....
Old Jan 16, 2010 | 07:20 PM
Whiskers's Avatar
Go Giants
Here is my house, the turn into the garage sucks.
Old Jan 16, 2010 | 07:37 PM
dallison's Avatar
registered pw
i am sure you can claim it under collision, but you will have your deductable and most likely your rates will go up a tad. In the long run it would be cheaper if you were to repair it out of pocket.
orrrrr, have the garage widened. that would be a suite mod.
Old Jan 16, 2010 | 09:06 PM
mitch14's Avatar
CL in lawnmower status
i'd be more worried about just showing everyone on AZine where you live
...so you hit the wall on the passenger side of the cars when turning in then?
what do your neighbours do? some of them seem to have a pretty close garage to driveway shape
Old Jan 16, 2010 | 10:38 PM
Costco's Avatar
so we finally find out the truth
Whiskers (and his wife) are both
Old Jan 16, 2010 | 11:08 PM
Shoofin's Avatar
I would change the drivers..
Old Jan 16, 2010 | 11:13 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Terry
Old Jan 17, 2010 | 06:33 AM
Street Spirit's Avatar
Is it because you have to turn at a right-angle to get into the garage?
Would backing in make it easier?
Any ground-level pics?
Old Jan 17, 2010 | 06:34 AM
Terry
Old Jan 17, 2010 | 06:48 AM
Whiskers's Avatar
Go Giants
Probably the best idea....
Old Jan 17, 2010 | 06:49 AM
Whiskers's Avatar
Go Giants
Me so horny.
Old Jan 17, 2010 | 06:58 AM
Costco's Avatar
Anyways... in all seriousness and after much deliberation, I think your best bet is to install a new garage, which has a better angle
Old Jan 17, 2010 | 07:01 AM
Whiskers's Avatar
Go Giants
I think the only option is to remove the two doors and make it one, but not sure on how to do that. Plus there is a poll inside...
Old Jan 17, 2010 | 09:34 AM
dallison's Avatar
registered pw
there's your problem, you've got a poll in your garage.
Old Jan 17, 2010 | 09:59 AM
knight rider's Avatar
Rooting for Acura
Could you pull into your driveway and position the car(s) to pull in backwards? That would make pulling out easier. You could also install parking sensors so that you don't hit the back wall
Other than that, find out if the pole (column) in your garage is load bearing. If not you may just be able to remove it.
Old Jan 17, 2010 | 10:03 AM
Shoofin's Avatar
So chop the pole off Just don't come back to me why your garage ceiling collapsed
Maybe re-do your driveway so you can drive straight up from the street instead of all those turns? Not sure if that's allowed, and then again straight down would put you onto a main road it looks like. If not maybe increase the pavement space on that last turn so it's large enoughf or you to maneuver w/o driving on the grass.
Wait- which side is your garage on? The right or left side of the pic?
Old Jan 17, 2010 | 10:07 AM
Shoofin's Avatar
I've got the perfect solution!
Old Jan 17, 2010 | 10:24 AM
NSXNEXT's Avatar
Must be a PA thing. We looked at a great house in Newtown that had a side-entry garage. There was literally no way (without driving on the grass) to get into the garage. It was ridiculous.
If you go the route of removing the center support, you MUST consult an engineer to determine if you need to beef up the header with either wood or steel.
Old Jan 17, 2010 | 10:53 AM
fsttyms1's Avatar
^ a lot of new subdivisions around here are building houses just like that. I think its stupid!
Talk to your neighbor. Go together and have the section of land between the 2 houses paved. You use his driveway to get into your garage and he uses yours. That way is a easier approach into???
That said, this is part of why you pay for insurance. If you arent making claims left and right your rates shouldnt go up, plus you are adults (well your wife may be ) and not kids so you should be ok.
Old Jan 17, 2010 | 11:11 AM
nj2pa2nc's Avatar
it's a car-drive it
as a former pa resident I have to say it is NOT a Pa thing.
Old Jan 17, 2010 | 11:26 AM
Costco's Avatar
I forgot that they made side entry garages, haven't seen one in awhile. who the hell thought that was a good idea? sheesh
Old Jan 17, 2010 | 12:51 PM
They do it to keep nice lines and flow so the side of the garage looks like another part of the house and not a garage (from the front of the house). Curb appeal.
Whiskers: Is it possible to just extend the driveway ~5 ft wider in that area to give you more space to make a wider turn?
Old Jan 17, 2010 | 01:43 PM
The Dougler's Avatar
Unofficial Goat
back in. and turn in your man card.
Old Jan 17, 2010 | 01:53 PM
Will Y.'s Avatar
This is probably the most practical approach, assuming there are no utility boxes, etc. located between the garages.
Whiskers and neighbor will have to record access easements for each other, though.
It's Whiskers, AZ's best known metrosexual-- didn't he already turn in his man card many moons ago?
Old Jan 17, 2010 | 01:58 PM
Whiskers's Avatar
Go Giants
My neighbor and I do drive on the grass between, so I guess we can still do that, but it doesn't always work.
Yes, pole :duh: Its probably load bearing, so don't know about the one garage door option.
Backing in won't work since I won't have enough clearance ahead of me without bumping into my fence.
Ill call the insurance company and ask what the procedure it, but since we both have damage in the front and real panels, I don't know what we will say the last hit was. Plus, will they care if we both have a claim...?
Its really the kind of thing that will really bother us unless we sell the cars, so not sure if we would even bother, especially since we will do it again.
Yes, turn in my man card...The worst part is something you don't even notice it until the next day, the slightest rub does a lot of damage. The Mr. Clean erasers get the paint from the house off, and touch up paint gets a lot done, but its still sucks.
I suck.
Old Jan 17, 2010 | 01:59 PM
Whiskers's Avatar
Go Giants
We would need to see who's property its on.
Old Jan 17, 2010 | 02:00 PM
Whiskers's Avatar
Go Giants
Seems to be go info....
Maybe a smart car is in order...
If it ever stops raining, Ill take pics of the damage of the Lexus and Infiniti...
Old Jan 17, 2010 | 02:16 PM
gixxer60097's Avatar
It will most likely be an at fault accident for you. I had $1000 worth of damage in a fender bender and a $500 deductible. So insurance paid $500. They raised my rates 25%
I called them and they said the monetary value doesn't matter. i would have been better paying out of pocket.
I haven't had an at fault accident in over 14 yrs and now they said I am a high risk driver for either 3 or 5 yrs, I forget.
I hate insurance companies...
Old Jan 17, 2010 | 02:19 PM
Whiskers's Avatar
Go Giants
Just called Geico and they will only fix one accident per car, so that would get one panel fixed, not sure if its even worth it....They they told me that I need to report any accidents to them regardless and I quickly hung up....Never gave them my policy number...
Old Jan 17, 2010 | 02:30 PM
Hapa DC5's Avatar
אני עומד עם ישראל
Make sure they can't trace you.... Hope you called from a blocked number
Old Jan 17, 2010 | 02:31 PM
Whiskers's Avatar
Go Giants
