Insurance Question
My wife and I have continuously driven into our house (our garage is at a bad angle). We probably have about 2K worth of damage each on our cars in various locations of the cars (mostly quarter panels). Will our insurance cover the repairs, or should we just let it be?
I wouldn't get insurance involved.
If I don't, then Im not getting it fixed...
Well, from the insurance company's perspective, it was your wife's and your fault that you damaged your cars, hence they mostly likely would not cover that. It was not an accident, so no claim will be made. Even if you asked, I doubt they would cover it. I would pay for the repairs out of pocket. :twocents:
It was obviously our fault.
(Post 11654489)
Striking the wall accidentally is a result of negligence which will be covered by insurance, unless Whiskers and wife are intentionally driving their cars into the wall to damage the cars or house. Fault is irrelevant to coverage. However, Whiskers should pick the most recent date(s) when the cars hit the wall if he makes a claim-- most policies have a reporting requirement (often 30 days from the incident date) to get coverage. If Whiskers & spouse wait for more than the XX days under the policy to report an incident, the insurer can deny the claim. |
Originally Posted by Whiskers
(Post 11654436)
I'm sorry Whiskers, I just find this funny. What do you mean continuously? Is there no way you can modify your garage? Or parking? Terry |
Get the cars fixed, then put some padding on the walls :tongue:
Originally Posted by Will Y.
(Post 11654656)
:what: :shakehead :no:
Originally Posted by teranfon
(Post 11654666)
:rofl:
Originally Posted by LuvMyTSX
(Post 11654689)
I need draw a diagram.... |
i am sure you can claim it under collision, but you will have your deductable and most likely your rates will go up a tad. In the long run it would be cheaper if you were to repair it out of pocket.
orrrrr, have the garage widened. that would be a suite mod. |
i'd be more worried about just showing everyone on AZine where you live :run:
...so you hit the wall on the passenger side of the cars when turning in then? what do your neighbours do? some of them seem to have a pretty close garage to driveway shape |
so we finally find out the truth
Whiskers (and his wife) are both :rice: |
I would change the drivers.. :dunno:
(Post 11654436)
(Post 11654666)
:rofl:
Is it because you have to turn at a right-angle to get into the garage?
Would backing in make it easier? Any ground-level pics? |
(Post 11654666)
:rofl:
I'm sorry Whiskers, I just find this funny. What do you mean continuously Terry :bitelip: |
Originally Posted by Shoofin
(Post 11655201)
Originally Posted by I Go To Costco
(Post 11655117)
Anyways... in all seriousness and after much deliberation, I think your best bet is to install a new garage, which has a better angle :2cents:
(Post 11655546)
(Post 11655548)
I think the only option is to remove the two doors and make it one, but not sure on how to do that. Plus there is a poll inside...
there's your problem, you've got a poll in your garage. |
Could you pull into your driveway and position the car(s) to pull in backwards? That would make pulling out easier. You could also install parking sensors so that you don't hit the back wall :dunno:
Other than that, find out if the pole (column) in your garage is load bearing. If not you may just be able to remove it. :2cents: |
So chop the pole off :dunno: Just don't come back to me why your garage ceiling collapsed :shrug:
:tomato: Maybe re-do your driveway so you can drive straight up from the street instead of all those turns? Not sure if that's allowed, and then again straight down would put you onto a main road it looks like. If not maybe increase the pavement space on that last turn so it's large enoughf or you to maneuver w/o driving on the grass. Wait- which side is your garage on? The right or left side of the pic? https://i46.tinypic.com/34zizb4.jpg |
Must be a PA thing. We looked at a great house in Newtown that had a side-entry garage. There was literally no way (without driving on the grass) to get into the garage. It was ridiculous.
If you go the route of removing the center support, you MUST consult an engineer to determine if you need to beef up the header with either wood or steel. |
^ a lot of new subdivisions around here are building houses just like that. I think its stupid!
Talk to your neighbor. Go together and have the section of land between the 2 houses paved. You use his driveway to get into your garage and he uses yours. That way is a easier approach into??? That said, this is part of why you pay for insurance. If you arent making claims left and right your rates shouldnt go up, plus you are adults (well your wife may be :snicker: ) and not kids so you should be ok. |
Originally Posted by NSXNEXT
(Post 11655734)
I forgot that they made side entry garages, haven't seen one in awhile. who the hell thought that was a good idea? sheesh
They do it to keep nice lines and flow so the side of the garage looks like another part of the house and not a garage (from the front of the house). Curb appeal.
Whiskers: Is it possible to just extend the driveway ~5 ft wider in that area to give you more space to make a wider turn? |
back in. and turn in your man card.
Originally Posted by fsttyms1
(Post 11655800)
Whiskers and neighbor will have to record access easements for each other, though.
Originally Posted by The Dougler
(Post 11656117)
My neighbor and I do drive on the grass between, so I guess we can still do that, but it doesn't always work.
Yes, pole :duh: Its probably load bearing, so don't know about the one garage door option. Backing in won't work since I won't have enough clearance ahead of me without bumping into my fence. Ill call the insurance company and ask what the procedure it, but since we both have damage in the front and real panels, I don't know what we will say the last hit was. Plus, will they care if we both have a claim...? Its really the kind of thing that will really bother us unless we sell the cars, so not sure if we would even bother, especially since we will do it again. Yes, turn in my man card...The worst part is something you don't even notice it until the next day, the slightest rub does a lot of damage. The Mr. Clean erasers get the paint from the house off, and touch up paint gets a lot done, but its still sucks. I suck. |
Originally Posted by Street Spirit
(Post 11656006)
(Post 11656132)
:nod: :stupid:
:werd: This is probably the most practical approach, assuming there are no utility boxes, etc. located between the garages. Whiskers and neighbor will have to record access easements for each other, though. It's Whiskers, AZ's best known metrosexual-- didn't he already turn in his man card many moons ago? :shrug: Seems to be go info.... Maybe a smart car is in order... If it ever stops raining, Ill take pics of the damage of the Lexus and Infiniti... :sad: |
It will most likely be an at fault accident for you. I had $1000 worth of damage in a fender bender and a $500 deductible. So insurance paid $500. They raised my rates 25%:what:
I called them and they said the monetary value doesn't matter. i would have been better paying out of pocket. I haven't had an at fault accident in over 14 yrs and now they said I am a high risk driver for either 3 or 5 yrs, I forget. I hate insurance companies... |
Just called Geico and they will only fix one accident per car, so that would get one panel fixed, not sure if its even worth it....They they told me that I need to report any accidents to them regardless and I quickly hung up....Never gave them my policy number...
Originally Posted by Snookie
(Post 11656193)
Originally Posted by Hapa DC5
(Post 11656229)
Make sure they can't trace you.... Hope you called from a blocked number :ninja:
