High beam question.
Old Jul 25, 2008 | 04:20 PM
CL-Slick's Avatar
Chillin' in my trailer
High beam question.
I just installed 9005 yellow high beams and they are 100watt. My stock bulbs were 60watt. Will the new 100watt bulbs melt the headlight housing?
Old Jul 25, 2008 | 04:28 PM
Moog-Type-S's Avatar
The sizzle in the Steak
It's possible......why not ask this in the CL forum?
Old Jul 25, 2008 | 05:54 PM
CL-Slick's Avatar
I did, no answer.
Old Jul 25, 2008 | 06:32 PM
Osamu's Avatar
I think I did something similar in my legend without problems. I think the wiring harness might be of concern, but considering at least I don't drive more than a few minutes with my highbeams on at a time, I was never that concerned.
Old Jul 25, 2008 | 06:34 PM
CL-Slick's Avatar
Same here, I only click them on to see signs so I guess it won't be a major problem.
Old Jul 25, 2008 | 06:48 PM
Sly Raskal's Avatar
i had 65w yellow 9005 bulbs in my cl before I got rid of it and it was fine. Why did you get 100watt 9005 bulbs?
Old Jul 25, 2008 | 08:32 PM
CL-Slick's Avatar
I wasn't paying attention.
Old Jul 25, 2008 | 08:35 PM
Sly Raskal's Avatar
Well, i wouldn't recommend putting a bulb that obviously shouldn't be used in your car.
Buy the right bulb and do it and avoid the possibility of problems later.
Old Jul 25, 2008 | 08:53 PM
fuzzy02CLS's Avatar
There are different types of these bulbs. Just cause it says 100W doesn't mean it is. Many bulbs have better optics that perform like a 100W but are really 65W. A lot of PIAA bulbs are this way.
If it is truly 100W then it's the wiring I would be more worried about. You could burn it out. But as stated your highbeams are not used much & if they are, for only shorts periods. You may be ok.
Also, Friday is slow here may want to give it a little time before you post the same question in another section.
Old Jul 27, 2008 | 10:53 PM
CL-Slick's Avatar
ok, thanks fuzzy. I was taking the car out to the sticks in Mississippi and just wanted some info before screwing something up.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
