Help...How do I remove pinstripes??
1-2-3-4-5-6-speeeeeed!!!!
Guys, before I start trying to remove my pinstripe on my 91 Integra, I just want to know how much of a pain in the ass will it be! I believe that it is taped instead of paint, but not to sure. If it is painted how do I remove it?? If it is taped, I can get it started but will it break in process due to its age??
thanks in advance!
thanks in advance!
CAFFEINE SLAVE
if it's painted - wet sanding and buffing
if you have clearcoat on the paint, it comes off real clean and you will never know it was there (unless your paint has faded substantialy)
I had mine removed from a local bodyshop and it cost about $70ish - can't tell I ever had it
ok, so I found out that it is taped. Best possible solution is hairdryer/heatgun?? How long do I have to keep the gun on a section for?
Homeless
Originally Posted by GINge!
Would the same apply for Dealer decals? I want to remove a N-O-R-T-H-W-E-S-T A-C-U-R-A
for the Top left of the trunck lid, looks like vynil letters...
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
shit. just get a plastic razor and patience. soak the shit in some sort of bug/tar remover being its a 13 year old car, and heat and remove. not bad at all. i tried doing it with a beater 94 altima i bought and it turned out the second half of the car was resprayed so it was covered with clear and could not be removed unless i put in a lot more work then i want so im pimping with the 1/4 pinstripe
Originally Posted by soopa
dont use a heat gun, use a hair dryer.
a heat gun can kill your paint.
it should just peel off. its not too hard.
goo-b-gone to remove any residue
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
