Help...How do I remove pinstripes??
Old Oct 30, 2004 | 01:52 PM
CLASSYCLS's Avatar
1-2-3-4-5-6-speeeeeed!!!!
Guys, before I start trying to remove my pinstripe on my 91 Integra, I just want to know how much of a pain in the ass will it be! I believe that it is taped instead of paint, but not to sure. If it is painted how do I remove it?? If it is taped, I can get it started but will it break in process due to its age??
thanks in advance!
Old Oct 30, 2004 | 02:26 PM
Jamz's Avatar
CAFFEINE SLAVE
if it's painted - wet sanding and buffing
if you have clearcoat on the paint, it comes off real clean and you will never know it was there (unless your paint has faded substantialy)
I had mine removed from a local bodyshop and it cost about $70ish - can't tell I ever had it
Old Oct 30, 2004 | 03:21 PM
CCns24's Avatar
Contagious
If its just taped, all you need is a hairdryer and some patience
Old Oct 30, 2004 | 03:38 PM
chef chris's Avatar
Homeless
What you need to worry about is if it's faded.
A car that age, it probably is. Even if the stripe comes off, you'll have one heck of a shadow.
Old Oct 30, 2004 | 04:01 PM
CLASSYCLS's Avatar
ok, so I found out that it is taped. Best possible solution is hairdryer/heatgun?? How long do I have to keep the gun on a section for?
Old Oct 30, 2004 | 04:24 PM
chef chris's Avatar
Homeless
Just enough to warm the glue, not long. Just try a small section and see how goes it. If it's not loose enough, heat it a bit more, but don't hold it in one place to long or you'll melt it. Hairdryer would work, but you may burn it up using it for so long.
Old Oct 30, 2004 | 09:54 PM
GINge!'s Avatar
Health's Angels
Would the same apply for Dealer decals? I want to remove a N-O-R-T-H-W-E-S-T A-C-U-R-A
for the Top left of the trunck lid, looks like vynil letters...
Old Oct 30, 2004 | 09:56 PM
mclarenf3387's Avatar
Old Oct 31, 2004 | 02:40 AM
Berner's Avatar
shit. just get a plastic razor and patience. soak the shit in some sort of bug/tar remover being its a 13 year old car, and heat and remove. not bad at all. i tried doing it with a beater 94 altima i bought and it turned out the second half of the car was resprayed so it was covered with clear and could not be removed unless i put in a lot more work then i want so im pimping with the 1/4 pinstripe
Old Oct 31, 2004 | 06:56 AM
soopa's Avatar
The Creator
dont use a heat gun, use a hair dryer.
a heat gun can kill your paint.
it should just peel off. its not too hard.
goo-b-gone to remove any residue
Old Oct 31, 2004 | 10:01 AM
CLASSYCLS's Avatar
thanks Soopa, I will try it out!! I will post once done.
Old Oct 31, 2004 | 11:19 AM
esCarbonie's Avatar
I thought this was going to be a thread about gAy-Rod or some disgraced yankee fan
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
