Half Power
Half Power
I have an old '87 Integra SE and over the last few months it occationally only has about half it's power. After stomping the accelerator a few times it will free up and run normal. Something is sticking... any ideas?
Thanks, Jim
Thanks, Jim
Any noises? leaks? what regular maintenance do you do to it.. etc..
I bought it new and have replaced just about everything on it at least once. My regular maintenance is just the oil, filter and plugs etc. The only leak is oil drips from bottom of the timing belt cover... I will replace the cam seals when I do the next belt.
After I get the power back it lasts for the rest of the time it's running that day. (My wife normally drives it... but so slow that she wouldn't notice the problem.)
ps. I'm new... what forum should I be using? Thanks
The RSX side would be the closest.. There's very knowledgeable members here (3G TL) though.. I would register and search clubintegra[dot]com.. there will be more specific responses there.
btw.. it sounds like the throttle body / cable. I would deep creep it and check / adjust the cable.. run some seafoam / b12 through the tank.. maybe seafoam the oil as well then oil change followed by tune up depending on when you last performed each..
I wouldn't foam the crank on a car that old just my opinion.
i would check the tension on the throttle cable. I would also use throttle body cleaner and clean it out. BUT i would put in the old plugs or get new ones, since you will blacken the ones that are in there from using the throttle body cleaner.
