civicdrivr's Z3 thread
Old Jul 16, 2019 | 12:32 PM
  #5601
civicdrivr's Avatar
Old Jul 16, 2019 | 01:50 PM
  #5602
Not much to update on - just some general maintenance. It was time to replace the stock plugs after 13,749 miles. I had gotten some random misfires and the powerband was a bit choppy at times, so I figured it was time. Besides, plugs on these cars are suggested to be replaced every 12-15k miles, especially when tuned. Overall, they didn't look too bad. I put in some Denso IKH24s gapped to .024", but a few people I've talked to have suggested closing the gap to .02-.022", which I'll probably do tomorrow night
Overall, the car drives much better then it did. It feels way stronger in the mid-range and the choppiness in the 2-4k rpm range is gone.
Other then that, I've got to pull some logs and send them off to a tuner I've been talking with to see if there's some improvements to be made to the base tune I'm currently running. I'm not expecting huge gains, but I'll be happy if driveability is improved even further.
Wat?
VW suggests 60k miles...
Old Jul 16, 2019 | 04:30 PM
  #5603
civicdrivr's Avatar
Originally Posted by SamDoe1
Wat?
VW also states the manual transmission fluid (and IIRC the rear diff) is lifetime as well
The 12-15k mile suggestion is not per VW specs, it's recommended by tuners. I'm only running about 5psi more then a factory R, but that will still kill the spark plugs much quicker.
Old Jul 17, 2019 | 09:35 AM
  #5604
What about it is killing the plugs?
The lifetime fluid thing is an argument that rages on for every car. Engineers test these things to several "lifetimes" before they say things like this so it all depends on what is considered a "lifetime". For the stuff we make, we rate the product life at 7 years but test to 21 years. Ain't no one using a medical device for 21 years so any "lifetime" parts will be just fine for much longer than anyone will use the device. I'm not sure I've ever heard of anyone burning out a MT because of dirty fluid. Autos, yes, but not manuals.
FWIW, buttons, switches, wires, hoses, etc are all also considered "lifetime" parts that get regular wear and use. I don't see anyone ever regularly replacing those items...
Old Jul 17, 2019 | 09:55 AM
  #5605
TylerT's Avatar
Turd Polisher
It really depends on the kind of plugs , but I am doing plugs every 5-10k due to them being the copper NGK BKR7Es. For how inexpensive they are compared to Iridiums, I'm okay with that change interval.
Old Jul 17, 2019 | 11:03 AM
  #5606
Aman's Avatar
Your Friendly Canadian
Old fluid might not grenade a MT but it will affect shift action and synchro life. All my friends who've turned up boost on their cars seem to eat spark plugs every other oil change. Don't know the science behind it though.
This stuff is so cheap and easy to do that they need very little justification IMO.
Old Jul 17, 2019 | 11:33 AM
  #5607
rockstar143's Avatar
lol...
OEM Sam doesn't compute the tuned maintenance intervals.
WAT!!?!?!
this also means the R stays a stage ZERO tune.
Old Jul 17, 2019 | 11:35 AM
  #5608
lol...
WAT!!?!?!
R will be going APR+ hopefully soon. That way I can keep the warranty.
I was just asking why a tuned car would eat plugs more than a normal car. I don't know the science of why so I was asking.
Old Jul 17, 2019 | 11:41 AM
  #5609
I'm just giving you a hard time, man...
that's awesome.
I would imagine just running more air/fuel through it...probably burns a ton hotter than normal and the plugs aren't intended to last as long because of it.
Old Jul 17, 2019 | 01:06 PM
  #5610
civicdrivr's Avatar
In short - more boost, more timing, and more heat = a stronger spark requirement which results in a shortened lifespan of the plugs.
The iridiums I'm running are heat range 8. The stock NGK iridiums are a 7, so these new plugs are one step colder (or a 24 per Denso's heat ranges). In other words, they provide more resistance to heating up compared to stock.
Replacing them once every 12-15k miles (which is a little over a year for me) is reasonable, since the Denso's are only $9/ea. If I were running the NGK R7437-9s, I'd be a little bit more annoyed since those are $40 each.
Old Jul 17, 2019 | 01:13 PM
  #5611
I ordered 6 plugs from amazon and 15 showed up.
Old Jul 17, 2019 | 01:14 PM
  #5612
Besos mi culo!
Old Jul 17, 2019 | 01:19 PM
  #5613
Aman's Avatar
Getting off topic. We're talking about spark plugs, J.
Old Jul 17, 2019 | 02:10 PM
  #5614
I remember helping a friend put an S/C on his Mk4 Jetta 1.8 & he had to go a degree colder on the plugs. I think his issue was them fouling excessively, was back in 2005 & I don't recall fully.
Old Jul 17, 2019 | 03:07 PM
  #5615
Cost isn't a big deal, agreed, but the fact that you have to do it kinda sucks.
More boost, probably, but timing is just a relationship between the camshaft position and the firing of the spark plug, that shouldn't impact #pluglyfe. I need to do some more research into heat ranges...
Fouled plugs are a result of incomplete combustion or excess non-combustible substances (ie coolant/water) in the chamber. If that's happening, something is wrong.
Old Jul 17, 2019 | 04:10 PM
  #5616
I moved back to Houston shortly after that, never saw the end of that project. Same with the Ford 302 FB RX7, was actually looking forward to getting that one buttoned up.
Old Jul 17, 2019 | 04:33 PM
  #5617
Yumcha's Avatar
Old Jul 17, 2019 | 05:12 PM
  #5618
civicdrivr's Avatar
While the timing of the spark itself wouldn't impact plug life, the environment in which the spark is taking place is different. There's way more to it then I understand though, so I'm not gonna pretend to know everything
Old Jul 17, 2019 | 05:25 PM
  #5619
Yumcha's Avatar
Only Ron A can say that he knows everything.
Old Jul 20, 2019 | 09:51 AM
  #5620
Predatorbird's Avatar
Bird is the Word
If you're concerned about changing spark plugs every 12-15k, tuning isn't for you
Old Jul 20, 2019 | 10:29 AM
  #5621
are u calling me a bitch?
if it's any consolation...I swapped plugs...then found out a month later I needed to gap them hos to .026 to be able to tune and gap them hos.
Old Jul 29, 2019 | 03:51 PM
  #5622
StreetKA's Avatar
i had to swtich to HKS 45XL or something like that they were 120 for all 4 - 2 steps colder than stock and need to be replaced every 30k or so
Old Jul 29, 2019 | 04:15 PM
  #5623
for $120 for 4 they'd be in my car like 100K miles.
Old Jul 29, 2019 | 04:18 PM
  #5624
civicdrivr's Avatar
So far I've not had any issues with the new plugs. The car feels a bit peppier above 4k, but that could be placebo. It definitely idles cleaner though.
Old Jul 30, 2019 | 06:07 AM
  #5625
Placebo is more important than dyno numbers imo.
I'm not even kidding.
Old Jul 30, 2019 | 11:55 AM
  #5626
1killercls's Avatar
GEEZER
Besos mi culo!
Mi culo es tu comida cabrones!
Old Jul 30, 2019 | 11:56 AM
  #5627
1killercls's Avatar
GEEZER
35k on my 2.0T original plugs still plugging!
Old Aug 5, 2019 | 07:40 AM
  #5628
civicdrivr's Avatar
Updated Mod List
- P3 vent gauge w/ performance timer pack
- CQuartz UK Ceramic Coating
- VW671 3D printed front license plate mount
- BMW rear license plate mount (gets the plate off of the paint)
- Audi S3 resonator delete kit
- ECS Flush Kit (10mm/17.5mm spacers)
- Intake snorkel trimmed
- Snow grate removed from factory airbox
- Weathertech Window Visors (not my favorite, but they help with wind buffeting when the windows are cracked)
- Raceseng Sphereology shift knob
- ECS front to back and side to side short shifter
- 42DD shift cable bushings
- OE VW shift cable bracket
- ECS shift cable bushings
- ECS SS clutch line
- Homemade adjustable clutch pedal stop
- Removed swirl valve and bleeder block check valve
- PowerFlex hybrid dog mount insert
- RocEuro stabilizer bar
- VW Homelink rearview mirror
- Euro low profile rear headrests
- Southpawboston OBD Eleven glovebox holder
- Eurodyne Maestro Stg2
- Llumar Formula One ceramic tint, 35%
- Forge Motorsports turbo blanket
- APR boost tap
- D-docks cell phone dock
- Superpro 22mm rear sway bar
- Acexxon rear reflector deletes
- VW aspherical sideview mirrors
- Integrated Engineering downpipe, coated by SwainTech
- SRP aluminum pedals
- Euro Dynamic Taillights
- Dieselgeek shifter shaft bushings
- Dieselgeek Super Pin
- Southbend Stage 3 Daily clutch with lightweight flywheel
- Fluidampr
- iABED billet rear main seal
- Black Forrest Industries stage 1 motor and transmission mounts
- Baun Performance front mount intercooler
- Burger Motorsports turbo inlet
- VW 12v outlet LED flashlight
- Motul Gear 300 transmission fluid
- Europower folding mirrors
- Tuxmat floor mats
- Ground Control adjustable springs (adjustable from 0 to -1.5" from stock)
- Superpro fixed camber plates (-1.4°) (removed)
- OE 19x8 Pretoria Wheels (removed)
- Bilstein B8 Damptronic struts
- Euro Sport Accessories Top Mount Camber Insert (-.8°)
- Motegi MR131 Traklites 17x8 +40
- 245/45-17 Michelin Pilot Sport 4S
- aFe Power dry filter
- Many coding tweaks
Old Aug 5, 2019 | 08:10 AM
  #5629
that looks grippy!
mi culo, su culo @1killercls
Old Aug 5, 2019 | 08:43 AM
  #5630
1killercls's Avatar
GEEZER
that looks grippy!
Muchas Gracias!
Old Aug 5, 2019 | 07:36 PM
  #5631
civicdrivr's Avatar
Took some quick shots this evening after a little rain. I'm loving the bronze.
It's a really tight fit over the brakes, and requires the weights to be placed slightly towards the center of the rim (shifted over by about 10mm) so it can clear the front calipers.
Turn in is ever so slightly dulled, but the ride is way better and overall handling is much improved with the PS4S's. I'm probably going to order a 5mm spacer for the rear since the wheels don't quite sit where I want them, but it's not a high priority.
Old Aug 5, 2019 | 07:43 PM
  #5632
civicdrivr's Avatar
I also decided to block off the resonator on the stock airbox in hopes that it would add a little bit more sound. Basically I took a small piece of plastic and glued it over the hole. Easy work.
Didn't do a fucking thing though
Old Aug 5, 2019 | 07:56 PM
  #5633
Yumcha's Avatar
Car's looking fabulous, dude.
Old Aug 5, 2019 | 08:05 PM
  #5634
civicdrivr's Avatar
Says the guy with a Sportback. That thing is fabulous
Thank you though. Wanna trade? My wheels and alignment are good.
Old Aug 6, 2019 | 06:38 AM
  #5635
I watched a video review of the RS5 Sportback.
I didn't realize it but they reverted to the tiptronic traditional automatic on the newer ones.
I'm assuming yours has that too?
Old Aug 6, 2019 | 06:48 AM
  #5636
civicdrivr's Avatar
Yeah they went back to the traditional auto on the S* cars because of the torque and smoothness IIRC.
Edit - yep, torque: https://jalopnik.com/the-new-audi-s4...sio-1730778195
Old Aug 6, 2019 | 07:16 AM
  #5637
All this being said, the eight-speed auto isn’t a bad transmission, even in a high-performance application. It’s a ZF design and I drove a previous iteration of it in the Audi RS7. It was perfectly fine on the highway and on the track.
Still, I’ll somehow miss the nerdy cool of the DSG, much as I’ll miss the stupidity of the three-pedal manual. I guess that’s progress.
Okay, perfectly fine is not what I would want to describe my transmission.
Gah...lmao, so now I have a small sense of pride for having DSG then.
Old Aug 6, 2019 | 07:46 AM
  #5638
Good choice on the bronze, they look great on the white.
Old Aug 6, 2019 | 08:07 AM
  #5639
Don't the 911's, Ferraris, and Lambos have a lot more torque and still use a DCT? What gives Audi?
Also, not just exotics. New Vette and GT500 also going with DCT's.
I like the color but hate the fact that there wasn't a set of Pretorias waiting at my door to install.
Old Aug 6, 2019 | 08:57 AM
  #5640
TylerT's Avatar
Turd Polisher
Morgan,
I'm definitely a fan of the wheel setup - meaty & functional (with the exception of the wheel weights ) ftw!
