civicdrivr's Z3 thread
Old May 17, 2019 | 02:06 PM
  #5481
civicdrivr's Avatar
Old May 17, 2019 | 03:25 PM
  #5482
Aman's Avatar
Your Friendly Canadian
Are you worried at all about ground clearance from the rear adjuster itself? I'm assuming that's what I see below the rear control arm.
Old May 17, 2019 | 03:34 PM
  #5483
civicdrivr's Avatar
It hangs about an inch below the rear LCA. It's still a good 8" above the ground. My front mud flaps hang lower and don't catch on much, plus the car has a slight rake - so if the adjusters are going to contact anything, I'm gonna need a new front bumper
Old May 17, 2019 | 04:29 PM
  #5484
Majofo's Avatar
It hangs about an inch below the rear....
Ah.. the J of rear adjusters...
  #5485
Majofo's Avatar
The Jofo on the other hand
Old May 17, 2019 | 04:33 PM
  #5486
civicdrivr's Avatar
Quite the dangle you have...
Old May 17, 2019 | 04:41 PM
  #5487
Majofo's Avatar
You should see my pillowballs
Old May 17, 2019 | 04:53 PM
  #5488
rockstar143's Avatar
Make me toe out
Old May 17, 2019 | 08:04 PM
  #5489
civicdrivr's Avatar
Old Jun 17, 2019 | 09:59 AM
  #5490
civicdrivr's Avatar
Quick update - the top hats are coming out this coming weekend. I had gotten them because of the increased negative camber, and as far as handling goes, the car is on rails. But from an NVH standpoint, I can't stand them. The car clunks over expansion joints and just sounds cheap. I've ordered these:
Basically, you remove the metal washer from the OEM top hat and slide in the new "washer", which has an offset strut mounting hole, which gives the car -.8* of added camber. It's not as much as the SuperPro top hats added (-1.4*), but since this retains the stock top hat bushings, it should be nearly stock in terms of NVH.
This exercise sucks because VW loves their stupid torque to yield bolts, so everything that I replaced when I did the suspension a month ago will need to be replaced again But I'll also be using this time to install the subframe deadset kit along with the rear camber arms, and then it's off to get an alignment at the start of next week.
Also - I'll probably be selling the Pretorias soon
Old Jun 17, 2019 | 10:09 AM
  #5491
CCColtsicehockey's Avatar
Volks inbound
Old Jun 17, 2019 | 11:40 AM
  #5492
civicdrivr's Avatar
No. I'm actually going the inexpensive route, and one that may not be very popular. I'm getting 17s
The wheels are under $200 each, so if one bends, it's no big deal to replace it. And tires are about $400 less for the set compared to a 19". Down sizing the wheels adds to the overall comfort of the car, which is my goal. I love a lowered car, but - in most cases - I hate the ride. Another benefit is weight. The wheels I'm looking at are 17lbs, and the tires are 22lbs. However, that's not happening right away. I'm waiting until until July 4th to see if there are any sales I can jump on.
In the meantime, I've ordered new struts. I wanted to replace them eventually, but since I'm replacing most of the torque to yield bolts now, I might as well do it all in one shot. I opted for some Bilstein B6s - they're intended to be used with lowering springs and they retain DCC. Pricey ($1300 for just the struts), but supposedly worth it. I'm hoping they get here by the weekend, if not, I'll be working late nights next week to get them in before taking a road trip Wednesday.
Old Jun 17, 2019 | 12:06 PM
  #5493
How old are you now? 50? Trading in steering response of small stiff sidewall 19s for some comfy sponge 17s
Love that you are focusing more on handling mods than power mods first.
Old Jun 17, 2019 | 12:57 PM
  #5494
rpf1 for sure.
Old Jun 17, 2019 | 02:12 PM
  #5495
civicdrivr's Avatar
Shit, I spent $40k on this thing, I don't want it to ride like a $4k Civic
Steering response may see a slight decline, but I'm hopeful that the camber adjustments and upgraded struts will bring it back.
rpf1 for sure.
Negative. RPF1s are over $200 each for the size I would need.
Old Jun 17, 2019 | 02:25 PM
  #5496
Saying it rides like a Civic could be unfair. I am sure an Ariel Atom has a rough ride too but wouldn't compare it to a Civic :wink:
For being a daily though I can see not wanting to feel like you have a flat tire while driving on shitty roads.
PRF1 would be a great option.
Old Jun 17, 2019 | 02:33 PM
  #5497
XXR, I knew it.
Old Jun 17, 2019 | 02:44 PM
  #5498
Old Jun 17, 2019 | 03:09 PM
  #5499
Old Jun 17, 2019 | 04:45 PM
  #5500
Majofo's Avatar
Never forget a black vinyl sticker covers the stupid ON/OFF symbol on Morg's volume knob
Old Jun 17, 2019 | 04:46 PM
  #5501
Majofo's Avatar
17s eh...
Old Jun 17, 2019 | 07:35 PM
  #5502
civicdrivr's Avatar
As usual, Maj figures it out first
Old Jun 17, 2019 | 08:18 PM
  #5503
Predatorbird's Avatar
Bird is the Word
Cheap, lightweight, and... flowformed? Konig?
Old Jun 17, 2019 | 08:42 PM
  #5504
civicdrivr's Avatar
I looked at some Konigs, but nope.
Old Jun 18, 2019 | 06:26 AM
  #5505
cheap 17's...
I'm going with American Racing!
Old Jun 18, 2019 | 02:30 PM
  #5506
1killercls's Avatar
GEEZER
I have 17's and Conti's on my A3. rides beautiful.
Old Jun 18, 2019 | 02:32 PM
  #5507
1killercls's Avatar
GEEZER
I'm 58 years old.
Old Jun 18, 2019 | 03:45 PM
  #5508
civicdrivr's Avatar
J was probably closest since the wheels I'm going with are under the same ownership as American Racing
I plan on getting Motegi MR131 Traklites. They're 17x8 +40. I'll also be running either a 235/45 or 245/45 tire - one spins 5 revolutions per mile less then stock while the other spins 6revs/mile more, so the difference is negligible.I'm inclined to run the 245s, but I plan on getting Michelin Pilot Sport 4S', and I'm not sure how true to size they are.
But yeah, they're 17.6lbs and the tires are 22lbs. That's only 2lbs per corner less then the Pretorias on there now, but the comfort and (hopefully) better pothole resistance is appealing.
This is what they look like (not my car):
They barely clear the R front brakes, and the wheel weight needs to be placed towards the center or rear of the barrel, not towards the face - otherwise it'll hit the calipers. It's a tight fit for sure, but I love the meaty tire look.
Old Jun 18, 2019 | 04:11 PM
  #5509
Aman's Avatar
Your tires are really gonna be heavier than your rims
That's a pretty wheel! I was kinda apprehensive about you going that small but I think it works with a simple 5-spoke design like that. It's got a nice no-bullshit look with the blank rotors.
How does your ride height compare to that GTI?
Old Jun 18, 2019 | 04:16 PM
  #5510
civicdrivr's Avatar
The height is about the same, maybe. Hard to tell due to the different tire profiles, but I'll tweak the height once everything is mounted to get it right.
Old Jun 18, 2019 | 04:27 PM
  #5511
Majofo's Avatar
Bro.. those are civic especiales
You live by your namesake
I like 'em!
Old Jun 18, 2019 | 04:32 PM
  #5512
Majofo's Avatar
Paint 'em Honda red
Old Jun 18, 2019 | 04:33 PM
  #5513
Majofo's Avatar
PSS 235s is plenty I'm sure.. but 245s fo all dat powah!!
Old Jun 18, 2019 | 04:58 PM
  #5514
civicdrivr's Avatar
Nah man, those are Rotas
I actually really like the bronze on white
Old Jun 18, 2019 | 05:00 PM
  #5515
Majofo's Avatar
Rotas > *
Old Jun 18, 2019 | 05:01 PM
  #5516
Majofo's Avatar
Aside from the shenanigans.. I meant it.. I like 'em!
Old Jun 18, 2019 | 05:14 PM
  #5517
civicdrivr's Avatar
This car tends to pull off the five spoke look pretty well, as long as they aren't 19s. The 19s just don't have enough tire to pull off the look.
Old Jun 18, 2019 | 09:04 PM
  #5518
Bird is the Word
Oh damn I forgot about those! Those are going to look great
Old Jun 18, 2019 | 09:47 PM
  #5519
Remind me of AP1 wheels...lightweight AF.
Nice, man...don't sell the other wheels just yet in case you hate how it looks.
Old Jun 18, 2019 | 11:56 PM
  #5520
civicdrivr's Avatar
Nah, fuck it - full send. Once I wash the car (after installing the suspension upgrades), I'm going to take some pics of the Prets and list them on Facebook. I've already sold the spare wheel for $300, so I'm only in the Prets for $650 right now. I should be able to come out ahead on them. I still have the stock Englishtowns too, so it's not like I won't have a backup. I may try to source some paint to touch up those scratches first though.
Speaking of the suspension parts, the new top mount inserts and struts are going to be delivered tomorrow. I'm still waiting on. The bolts to come in at the dealership. Really hoping they have them by Friday.
