Car dies while driving when hot outside
Old Apr 8, 2016 | 02:18 PM
JHerna04's Avatar
Hey so I can't seem to find out the exact problem with my 91 Acura Integra LS. Starts up fine and idles alright. During the day if it's hot outside mid driving the car will shut off (at night/ cooler temps there's no issue). No choking of jerking motions just clicks off and it'll be in auxiliary mode. Battery and alternator are perfect. The only thing that has stood out is a possible Crankshaft position sensor issue but I have no clue otherwise. Definitely let me know if you have any ideas
Old Apr 8, 2016 | 02:20 PM
1killercls's Avatar
GEEZER
Kanuter valve?
Old Apr 8, 2016 | 02:22 PM
1killercls's Avatar
GEEZER
All kidding aside...Thats a pretty old car...and that is not a lot of info to go on.
Old Apr 8, 2016 | 05:01 PM
Chief F1 Fan's Avatar
Here's your problem: it is 2.5 decades old and I'd move the thread except there is no where to move it to.
Old Apr 9, 2016 | 05:19 PM
Nitin's Avatar
But I just got here
Replace the car with a new one. That should fix the problem.
Old Apr 9, 2016 | 10:39 PM
01acls's Avatar
When it cuts off, if the dash lights are still light up, then probably the fuel pump relay. If not then probably ignition switch.
I would change both just to be safe since it's so dangerous to have a car cut out when driving. No power to get it off the road, no power steering, and no power brakes.
Old Apr 11, 2016 | 03:08 PM
Booya4139's Avatar
Shot in the dark, but we had a company A8, and it had a similar problem. The issue was that the ecu had a crack in it. and when it got hot, it expanded until it gap in the crack shorted the system and it shut down.
Old Apr 13, 2016 | 10:34 AM
Doom878's Avatar
Does your car have a temp gauge? If so, does it shoot up when this happens?
Old Apr 13, 2016 | 11:40 AM
1killercls's Avatar
GEEZER
Old Apr 14, 2016 | 09:48 PM
csmeance's Avatar
sounds like the fuel pump overheats and stops working...
Old Apr 15, 2016 | 09:55 PM
WheelMcCoy's Avatar
25 years gives it classic car status! OP is not held to modern emission standards. If he can maintain his car, more power to him!
Old Apr 17, 2016 | 03:37 PM
apaper's Avatar
6th Gear
MAF (Mass Air Flow) sensor bad? This would create the symptom you're describing...
Run an OBD scan. What errors surface?
Old Apr 17, 2016 | 08:53 PM
Midnight Mystery's Avatar
Null and proud of it
I really don't have much of an idea of the problem, I remember 1990-1993 CB7 Accords had a similar problem as well, which may have similar from your Integra... The engine and drive train are different I think (should be Civic or Prelude) but I assume many electronic parts aren't and I think it was a fuel related relay...
Glad to see another vintage Acura/Honda lives on...
Best of luck!!!
Last edited by Midnight Mystery; Apr 17, 2016 at 08:56 PM. Reason: Got Integra mixed up with Legend, sorry
Old Apr 17, 2016 | 09:14 PM
Nitin's Avatar
But I just got here
Just let your car die in peace man
Old Apr 19, 2016 | 05:55 PM
kurtatx's Avatar
Azine Jabroni
Car Donation - Donate Car to Kars4Kids
nore03
May 4, 2016 02:10 PM
Evilocity
Apr 22, 2016 09:33 AM
ond
Mar 23, 2016 05:47 PM
synth19
Mar 1, 2016 05:43 PM
