Brake Job lube
Old Aug 3, 2017 | 11:04 AM
Jakes_tl's Avatar
Brake Job lube
I know this can be a very debatable topic but my question is what type of lube do you use when replacing your brakes? I know there are a lot of car enthusiasts on this forum that are carefully about what they use.
Old Aug 3, 2017 | 11:09 AM
For what part of the brake job? Many caliper guide rods are listed as non-lubricated so obviously don't lube those. If they are lubricated use silicone or other specific brake caliper grease (the manufacturer will sell this if you want the OE stuff). For the pads themselves I use Brake Quiet by CRC.
Old Aug 3, 2017 | 11:20 AM
Jakes_tl's Avatar
I know for caliper pin guides you should be using silicone grease like 3M silicone paste or AGS Sil-glyde but for metal to metal should I be using silicone grease or brake anti-seize?
Old Aug 3, 2017 | 11:21 AM
dallison's Avatar
registered pw
I'll have to check the tube when i get home.
Old Aug 3, 2017 | 11:26 AM
What metal to metal are you talking about? Pad backer to caliper? If so, they make specific high temp grease for that application.
Old Aug 3, 2017 | 11:34 AM
Jakes_tl's Avatar
Back of the pad to caliper and brake pad ears.
Old Aug 3, 2017 | 01:43 PM
KaMLuNg's Avatar
brake quiet by CRC on everything...
Old Aug 3, 2017 | 01:49 PM
except the braking surface obviously (but have to say it anyway..
Old Aug 3, 2017 | 02:02 PM
Jakes_tl's Avatar
I don't know about using CRC brake quiet on caliper guide pins or anything that comes in contact with rubber. Looks like it will work on any metal on metal surfaces.
Old Aug 3, 2017 | 02:27 PM
KaMLuNg's Avatar
naw i use wd40 for that!!! keeps the rust off...
Old Aug 3, 2017 | 02:50 PM
It's a synthetic grease that is safe on plastic and rubber
Old Aug 3, 2017 | 04:51 PM
Brake quiet by CRC for that. Silicone brake grease for pins.
Old Aug 3, 2017 | 07:22 PM
oonowindoo's Avatar
This is not a very debatable subject. What is debatable is if you need lubing for brake or rim
