Air sound while driving
Old May 3, 2012 | 08:24 PM
buckyballs's Avatar
while im driving i hear almost like air or wind sound coming from the driverside. yes the door is closed all the way. the seal around the door and window is not ripped or missing. it looks completely sealed. its quite loud while im driving. any ideas?
Old May 3, 2012 | 11:13 PM
rossv1's Avatar
I have this problem too except with the passenger door.
Old May 4, 2012 | 02:34 AM
speedemon90's Avatar
was it always like that? Could be just the car itself.
Old May 4, 2012 | 03:04 AM
SubrinaIsMyCar's Avatar
7th Gear
You can see if you are leaking or have holes by watering your car to see if inside gets wet.
Old May 4, 2012 | 04:33 AM
civicdrivr's Avatar
What year/car do you have? Hondas/Acuras arent known for being silent, but if its really loud, thats not exactly normal.
Old May 4, 2012 | 01:16 PM
Will Y.'s Avatar
Registered but harmless
1) Check the outside driver's mirror mounting points for tightness & damage-- make sure it isn't loose or out of position.
2) Slip a piece of paper into the closed door and run it around the door frames to see if there's a spot where the paper gets loose to check for a bad door seal.
3) Wipe down the weatherstripping & door seal with 303 Aerospace or silicone lube-- if the noise decreases, it's excessively dry weatherstripping.
G/L, and welcome to AZ.
Old May 4, 2012 | 05:45 PM
JS + XES's Avatar
I drive a Subata.
Adding an aftermarket exhaust will surely solve that problem.
Welcome to AZine!
Old May 4, 2012 | 05:52 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Turn up the radio
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
sputik
Sep 7, 2015 01:40 PM
dlknight
Sep 3, 2015 07:54 PM
