Acura Integra Starting Problem
Old Apr 19, 2010 | 03:33 PM
Tiggy's Avatar
5th Gear
I have a 92 Integra which has starting issues. It seems to be a hot weather problem. (the won't start at gas station or after short stops) I have replaced distributor, fuel filter, the relay thingy on the distributor. Tested fuel pressure and it's good. I am thinking that it may be the main relay. I tried the "banging on the dashboard" thing to try to start it and it tries but won't quite start. The weird thing is that witht the key off, when I bang on the dash the tach moves up and down a bit. Should I try replacing the main relay or does anyone have any other ideas to try? Would it help to leave doors open to cool it down and then try to start it? Many thanks, would rather not have to bother my son again.
Old Apr 20, 2010 | 08:09 AM
NSXNEXT's Avatar
Yup, replace the main PGM FI relay. I had that problem in my 91 Integra.
Also the tach jumped on mine as well when I banged on the dash. Totally normal.
Old Apr 20, 2010 | 06:32 PM
Tiggy's Avatar
5th Gear
Thanks very much, I think I'll give it a try.
Old Apr 20, 2010 | 06:37 PM
FiftyFive's Avatar
Moderator Alumnus
2nd on the main relay,
Old Apr 21, 2010 | 04:32 AM
Shotgun3131's Avatar
chronic lurker...
With the ones I had I replaced a PGM FI and a Ignition Coil once. This was on a 91 and a 94.
Old Apr 21, 2010 | 04:46 AM
SpiderX1016's Avatar
Check the relay before you go out and replace it.
Have you checked the fuel pressure when the it happens?
Old Apr 24, 2010 | 01:57 PM
Tiggy's Avatar
5th Gear
Ok so we replaced the main relay and it starts like a dream. However now it is running rough during acceleration and the tach is jumpy when it goes rough. Could it be the ignitor or ignition module? I've done the dist. cap, coil, fuel filter etc. etc.
Any help would be appreciated...
Old Apr 24, 2010 | 07:31 PM
Tiggy's Avatar
5th Gear
As it turns out I am not smarter than a fifth grader....I bought the ignition module today and when I popped the hood I discovered that all of my bolts on my distributor cap were extremely loose. After tightening them she runs awesome again!! I then went back to my local Lordco store with my tail between my legs and admitted that I should be a blonde...
Old Apr 25, 2010 | 09:19 AM
NSXNEXT's Avatar
Don't you just love when you can fix things yourself.
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
