-2 camber and regular tire wear
Can someone tell me if rear tires with a -2 camber will need a camber kit? say if we have everything else in check, like the toe? On an Infin...I mean, Acura TL.
-2 is starting to get to the point where it will cause wear. If you rotate the tires often iw will significantly reduce the wear. (given the front end alignment is to spec)
OP, are you slammed at all?
You might be OK at -2, hard to know for sure. Is everything else in spec?
I'd keep an eye on the inside tire edge tread and rotate regularly
dang i should look at my back tires and see how they are wearin... if i get the camber kit for the rear i deff gota roll the back fenders cuz as it sits now i can just squeeze my finger between the side of the fender and tire sidewall
Marcus (Heeltoe) wrote an good article about camber kits and wear. I could be wrong but IIRC, he pretty much said that camber won't really cause the wear. It's the toe that will cause the wear.
Recently, I experienced tire wear related to toe on my FX. The toe will cause the entire tire to wear really really fast.
この道は毛むくじゃらのマンコだらけ..
-2.5 Front, -4.6 Rear right now. I flip my tires every 5000 Mi, so I don't really have a problem. You'd be fine at -2 camber as long as your toe is in check.
I still go to get my alignment checked 2X a year regardless..... toe goes out of spec over time. This is when having lifetime alignment is great. If you have a Discount Tires or a Firestone nearby, take advantage of it to the fullest... but treat them well! I have a pretty good relationship with the workers at Discount Tire near my place.
CL in lawnmower status
-3 all around, just flipped my tires at 30000kms(18000 miles) or so cuz i noticed some more wear on the inside, but nothing too crazy... and those tires were already used before at factory camber for probably a long time
and with mine only the very corner (outer half inch or so) of the tire was wearing out a little faster than the rest
thanks everyone for your input.
mods caught me
considering that the g's staggered, i'm assuming rotating the tires won't do much? poop...i'll need a camber kit
mods caught me
![what](https://acurazine.com/forums/images/smilies/what.gif)
この道は毛むくじゃらのマンコだらけ..
Actually I bring them coffee/frapachinos sometimes. The manager's real cool and he brought his 69 Vette to show to me.
I run staggered too.
Flip the tires..... that's what I do... Just tell them to flip the rears... it's just unmounting and remounting.
Take off the left tire and put it on the right wheel; take the right tire and put it on the left wheel.
Chapter Leader
(Northeast Florida)
(Northeast Florida)
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Just got the adjustable camber kit for the rear of my 04 Honda Accord lowered on the HFP suspension kit. I was experiencing severe tire wear on the inside rear tires.
Is it easy to install the camber kit? I just have to take out the old bar and install the new ones right?
nuldabz
09-03-2015 05:49 PM
