Cameras & Photography Because there aren't already enough ways to share photos...
Playing around with HDR...
Old Aug 29, 2008 | 01:37 PM
jmkiang's Avatar
zaino'd
Hey guys, I've been shooting in NEF+JPEG mode on my D40x just so I can play with them in Photomatix.
Anyway, I would like some advice/tips on my results.
Just an FYI, the original was shot with ISO200, f/5.6. Sunny as hell outside. Should I have used ISO100?
Before JPEG:
After NEF->HDR->JPEG:
Old Aug 29, 2008 | 02:00 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
what bracketing did you use
Old Aug 29, 2008 | 02:05 PM
stogie1020's Avatar
Needs more Lemon Pledge
What the heck is NEF?
Old Aug 29, 2008 | 02:13 PM
rimz's Avatar
now with four rings
Nikon Electronic Format
Old Aug 29, 2008 | 02:20 PM
stogie1020's Avatar
Figured it might be Nikon RAW format...
Old Aug 29, 2008 | 04:56 PM
ChodTheWacko's Avatar
Moderator Alumnus
I suspect you could have achieved the same thing by just playing with the histogram curve. HDR doesn't really show its strengths until you use multiple images.
- Frank
Old Aug 29, 2008 | 05:52 PM
Evader's Avatar
Let's Go Pens
I love how HDR looks. This looks like it's going to have to be my next thing to play with... UGh!! and to think I'm still trying to figure out an easy way to do B&W w/ Color, lol
Old Aug 29, 2008 | 06:22 PM
rimz's Avatar
now with four rings
2 layers....color on bottom, black and white on top...erase portions of black and white layer...color shows through...
Old Aug 29, 2008 | 06:33 PM
Mizouse's Avatar
imo HDRs are retarded looking, at least how everyone does them.
Old Aug 29, 2008 | 08:57 PM
rimz's Avatar
now with four rings
hey...my avatar is anything but retarded...
Old Aug 29, 2008 | 09:12 PM
Dan Martin's Avatar
Photography Nerd
I want to see some HDR photos of retards...
Old Aug 29, 2008 | 09:16 PM
jmkiang's Avatar
zaino'd
- Frank
Well, can you do this in CS3? I will play around with it this weekend. I would love to take multiple pictures at different exposures but I don't have a tripod yet so whenever I try, the overlays look f'd up. When I finally get it, its the first thing I'll try!
What do you mean? Sorry... not familiar with the lingo yet
I love the look of HDRs. I just need to get better at making them.
Old Aug 29, 2008 | 09:17 PM
Dan Martin's Avatar
Photography Nerd
I'm going to hell for this:
Old Aug 29, 2008 | 09:23 PM
Dan Martin's Avatar
Photography Nerd
If you shoot on high speed drive, you can probably rattle off 3 frames without much movement. It helps if you can brace yourself off something, but I've done a few freehand.
Old Aug 29, 2008 | 09:44 PM
drigo's Avatar
thats so fucked up dan...
go corkie!
Old Aug 29, 2008 | 09:58 PM
stogie1020's Avatar
Wow. Just wow. I'll save you a seat...
Old Aug 29, 2008 | 11:07 PM
csmeance's Avatar
if you have just 1 JPEG image, go into photoshop, then go to image, adjustments, exposure, then do -2, then save, then undo it, then -1, then save, then undo then +1, then save, then undo, then +2, this way you will get a lot higher range to put into photomatix.
Then put it into photomatix and make sure it is -2, -1, 0 (orignal), +1, +2
Old Aug 30, 2008 | 12:33 AM
jmkiang's Avatar
zaino'd
But don't you need to adjust the settings between each shot?
Hmm, didn't know Photomatix took JPGs... I see that it does now. I'm gonna try this out! Thanks
Old Aug 30, 2008 | 12:44 AM
Evader's Avatar
Let's Go Pens
So I was playing around with photomatix... I didn't have two identical images of the same exposure so I was playing around with combining two images to see what would happen. Here is a result of one which isn't that great but I like the effect.
<a href="http://www.flickr.com/photos/evader/2809745455/" title="hdr-test by Evader87, on Flickr"><img src="http://farm4.static.flickr.com/3102/2809745455_434d24fc86_b.jpg" width="1024" height="663" alt="hdr-test" /></a>
Old Aug 30, 2008 | 03:04 AM
S14 n Tsx's Avatar
mmmmmm....
^^^ummm wtf?
Old Aug 30, 2008 | 07:53 AM
Dan Martin's Avatar
Photography Nerd
That's what AEB (auto exposure bracketing) is for.
On most models, it will take three shots at different shutter speeds when you press the shutter. You'll get one underexposed, one regularly exposed, and one overexposed shot. Typically you can control the spread between shots, anywhere from a 1/3rd EV to 2 or 3EV. I find that 1EV is good for most shots, but if you want something more dramatic, try 2EV.
The more frames you capture, the less noise you'll have in your final image.
The problem with torturing a single JPG into a "HDR" image is you just don't have enough data in that file to extend the dynamic range. JPGs are only 8-bits. Your monitor can most likely show all 8-bits at once, so you're looking at everything that is contained in that file right now.
RAW files are 12, 14, or even 16-bits, so there's a lot more data to work with there. The term "HDR" is really being misused because what you're doing with applications like Photomatix is taking the data that's contained in those 12 to 16-bits and compressing it down to 8-bits so you can see it all at once.
You can use Photomatix on a single 8-bit JPG and you'll end up with an effect just like my developmentally-challenged superhero. It just won't be an HDR image.
Old Aug 30, 2008 | 08:42 AM
EuRTSX's Avatar
@ dan's picture.
Old Aug 30, 2008 | 11:19 AM
jmkiang's Avatar
zaino'd
Gotcha. Well, just got my tripod so I'm gonna try this the real way. I'll look thru my manual to see if my camera does AEB.
Haha interesting picture...
Heres one I tried with the PS method... exposure levels at -2, -1, 0, 1 and 2.
Old Aug 30, 2008 | 11:41 AM
Evader's Avatar
Let's Go Pens
^Nice! I'm going to probably pick up a tri pod from best buy today. I'm looking the carbon fiber one. since it's pretty light but sturdy
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
lbabus
Oct 12, 2015 07:00 AM
hashbrown
Sep 29, 2015 12:13 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
