Wiring From HU to Stock Amp
Old Oct 18, 2002 | 10:34 AM
McChicken's Avatar
Gentlemen -
Is the audio path from the head unit to the stock amp line level or speaker level? I want to add an equalizer to increase the bass level. I am not interested in doing the obvious (like adding a sub) and want to keep things simple. The rear 6x9 speakers can pump more bass, it just needs to be boosted.....
Old Oct 18, 2002 | 12:31 PM
mcdanjw's Avatar
Line level...
I am using a AudioControl 4.1 in a way similar to what you're looking to do. Works fine.
I don't know how much more bass that will produce without a subwoofer though.
Old Oct 18, 2002 | 01:02 PM
Bluto's Avatar
Find beauty in dissonance
Another idea .... I added Dynamat extreme to the rear deck and cross beams, fixed my 3rd brake light rattle. It sounded like the 6x9s had better response, my rattle/vibrations were gone, and there was more bass. I only had it a few days before I installed a sub. But, the stock system sounded much better with the dynamat installed. I'm sure an EQ will help. But more bass will increase rattles and vibrations. You might want to consider doing both. The rear deck was easy to Dynamat. I have not noticed any smell with the extreme.
Old Oct 18, 2002 | 01:04 PM
mcdanjw's Avatar
How does the rear deck come apart? Do you have to do anything from the 'trunk side' or can it all be done from inside the passenger compartment?
I don't want to take out my box if I don't have to.
Old Oct 18, 2002 | 01:28 PM
Bluto's Avatar
Remove the rear seat:
Pull up on the front of the rear seat cushions, they pop out.
Un-screw the center console, remove.
Un-screw the seat back anchors.
Lift seat back up then out.
Pull the C-pillar covers off.
I believe the rear deck slides foward, then up to remove off.
The only thing from the trunk side are the nuts holding the third brake light on.
Some pics...
http://www.acura-cl.com/forums/showt...ar+third+brake
I used several small pieces of Dynamat to do the rear deck.
4drviper
Apr 23, 2025 07:13 PM
Curious3GTL
Money & Investing
Nov 2, 2015 10:10 PM
RobbDizzle
Oct 15, 2015 11:16 AM
SUPRMN84
Oct 7, 2015 09:46 PM
TLCEEZ
Sep 24, 2015 02:35 PM
