Wire Radar detector directly to overhead lights? CL
Rag & Bone
Hey guys, a friend of mine spliced the overhead light socket wires on top of his rearview mirror and somehow wired it to his radar detector, you think its possible in my car to do the same thing, i'm gonna buy an extra power connector to fiddle with it. you think it can be done?
thanks for the input
Sig Rho's Finest
what i did was get a mini add-a-circuit from autozone and tap into the windshield wiper fuse. i also got the hardwire kit for my radar and just attached the positive wire to the adda circuit and grounded the kit to an exisiting ground bolt near the fuse box. i then just ran the wire up to the rearview mirror for the radar.
i wouldnt want to splice anything in case it ever shorts out
Rag & Bone
well all i did was cut it open and strip a small section of wires
![](http://images10.fotki.com/v197/photos/5/52702/278442/installpics-vi.jpg)
then i didn't want to soder* (*sp) it to the metal pieces...
see the little meat pieces next to the hole for the bulb, that are fixed to the plastic..
![](http://images10.fotki.com/v195/photos/5/52702/278442/installpics1-vi.jpg)
so i just wedged the wire between the bulb ends and the metal pieces
![](http://images9.fotki.com/v177/photos/5/52702/278442/installpics2-vi.jpg )
![](http://images10.fotki.com/v196/photos/5/52702/278442/installpics3-vi.jpg)
if you don't want to cut off the extra cord make sure to feed it over the fitting...
![](http://images10.fotki.com/v195/photos/5/52702/278442/installpics4-vi.jpg)
then put everything back and your done
![](http://images10.fotki.com/v194/photos/5/52702/278442/installpics5-vi.jpg)
now to turn it on all i do is press the button
VP Electricity
1 Post
Your wiring looks unsafe and prone to shorting out that would take out the DL fuse. THat fuse is also probably the radio constant.
And your coil cord coming out like that looks kinda weak. Can you get a straight cord for your RD?
Are you telling us that this thing only works when your dome light is turned on?
Rag & Bone
technically yes but i covered the bulb to block the light
Sig Rho's Finest
heres my setup, i know its hard to make it out but i hope it helps a little
![](http://memimage.cardomain.net/member_images/9/web/561000-561999/561686_12_full.jpg)
TL no more!
cycdaniel
12-17-2019 10:58 AM
chrisr
12-04-2015 02:17 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
sockr1
10-01-2015 01:31 AM
