what size door speakers for 2nd gen tl
Old 01-25-2008, 05:59 PM
here comes the snow!
sfont012's Avatar
not sure what size door speakers to buy. Also, whats a good 2 or 3 way speaker, i dont really wanna put holes in my doors for all the seperate component speaker parts.
Old 01-25-2008, 06:19 PM
fuzzy02CLS's Avatar
See the audio sticky at the top...
https://acurazine.com/forums/audio-video-electronics-navigation-22/%2A%2Aaudio-video-diy-info-faq-all-models-%2A%2A-299065/
Old 02-03-2008, 09:24 PM
caligirl2k's Avatar
https://acurazine.com/forums/showthread.php?t=299065
From what I see that still didnt anwer his question Im trying to find out the same thing.. Any other info for us..
Old 02-03-2008, 10:23 PM
salvo24's Avatar
You can go with 5 1/4" or 6 1/2" speakers. Either way, you will need spacers for them. .5" spacers are perfect as long as you keep the mounting depth of the speaker at or under 2 1/4". I've heard people use 3/4" spacers, but it seemed like the speaker just cleared the door panel with the .5".
I just got my Pioneers in....camera wasn't working, so I wasn't able to do a DIY or take pics to help you out....but honestly once I figured out my plan of attack, it took 10 minutes to pop them in.
So heres a quick step by step if you guys need info:
Things needed:
-Speakers
-Spacers
-Drill and a small drill bit
-Phillips screw driver
-Electrical tape
-Pencil or marker
-8 screws for drilling into metal
-8 1/4" or 1/2" screws (these are for the speaker going into the spacer, the screws provided probably wont work)
Process:
-Take off the door panels, there is a DIY on the 2G forum
-Unscrew the stock speakers and disconnect the wires.
-Snip off the connector on the wire
-The spacer will fit right in the groove in the door around the speakers, hold it in place and mark off where the screw holes belong.
-Take the drill and the bit and drill holes where the markings are.
-Place spacer back in its location and drill it in place with 4 screws.
-Connect speaker wire (which most likely came with new speakers) to the wire ran in the door. Solder them together and cover with electrical tape.
-------Tip: use a lot of extra wire, if it is tight, you may run into a problem when you roll the window down...the glass may pull on the wire and disconnect the speaker)
-Place speaker in place and use the 1/4 or 1/2" screws to screw it into the spacer. (Length is a big deal for this....if you have a 1/2 spacer, obviously the screws will need to be smaller, if not, it will just hit the metal on the door.)
-Put panel back on the door and you're done
Old 02-03-2008, 11:12 PM
caligirl2k's Avatar
02-25-2020 09:57 AM
akbears15
15
11-05-2015 07:06 AM
coykiam
09-11-2015 03:43 PM
Quick Reply: what size door speakers for 2nd gen tl
