what amp??
Old May 4, 2007 | 11:43 PM
misterdannyboy's Avatar
what amp??
What would be a good amp for the time being to push 2 kicker cvr 12"
100-150$$
Old May 5, 2007 | 12:47 AM
G22_Powered_YA1's Avatar
for those of us not familiar with kicker, how much power is the rated RMS handling????........ should be written on the box or something
Old May 5, 2007 | 01:11 AM
dreem1er's Avatar
deal with it
yeah wow.....you really need to either give those numbers or at least say the exact model CVRs have been around around forever and the old ones had like 400 peak....the new ones are 800 peak......
Old May 5, 2007 | 01:25 AM
dlersch's Avatar
100-150$$
none for that kind of money, unless you want crap.
Old May 5, 2007 | 02:51 AM
even then Peak means almost nothing... in the end RMS is what counts most
Old May 5, 2007 | 06:05 PM
dreem1er's Avatar
deal with it
it was really to just make a point the new has a rms of 400 and the old one i think was like 150-200
Old May 5, 2007 | 06:47 PM
sorry it has an rms of about 400w .. i just miss the thumping.. i can't afford an expensive amp right now
Old May 5, 2007 | 07:43 PM
Osamu's Avatar
what's the VC Config? DVC 4?
or what will be the final impedence load? 1 or 2 ohm?
Old May 5, 2007 | 07:58 PM
Osamu's Avatar
i'm thinking something a long the lines of:
Phoenix Gold R8.0.1
Directed D1200
but I've never tried either of these before. I've also heard good things about clarion amps, but don't know much about them.
Old May 5, 2007 | 08:28 PM
will a kenwood 1000 watt 2 channel be ok..KAC-7203
Old May 5, 2007 | 08:30 PM
4 ohm voice coils 400w rms 800 peak
Old May 5, 2007 | 11:56 PM
in the case that its SVC 4s then it will be a net 2 or 8-ohm load
in the case that its DVC 4s the it'll be 1 or 4 ohm net load depending on wiring setup
most all amps are 4 and 2 ohm stable, not many cheap ones will be 1 ohm stable, amps will deliver to 8 ohms but you wont get much power at all
Old May 8, 2007 | 12:25 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You need to budget a little higher if you want something that's really gonna drive those subs
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
