variable speed sensor 2nd gen tl
Old Feb 21, 2008 | 12:42 PM
sfont012's Avatar
here comes the snow!
im tryin to figure out where this is because i'd like to do my own install. Finding and splicing to this vss sensor sounds like the hardest part.
btw- connection to the vss is necessary for gps nav.
Old Feb 21, 2008 | 03:03 PM
c0v3rr1d3's Avatar
i found the easiest place to tap this wire is in the instrument cluster connectors.
it can be found in Connector C Pin 2 a Blue/White Wire
Connector C is the middle Connector 14 Pins Total.
This is for a 00-03 tl. the 99 have to connect differently
Old Feb 21, 2008 | 03:57 PM
sfont012's Avatar
cool, thanks alot.
by chance do you know where i can get some pics, or will it be obvious when i take the instrument cluster off?
Old Feb 21, 2008 | 06:53 PM
uncald4's Avatar
Former Sponsor
Vehicle Speed Sensor = VSS.
Look right above your gas pedal. You'll see your cruise control module. Unplug it. In the harness you will see a blue wire with white stripe. That is your VSS wire. Enjoy!
Old Feb 21, 2008 | 07:36 PM
sfont012's Avatar
thanks guys!
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Frathora
Sep 28, 2015 11:29 PM
DS2000TL
Sep 9, 2015 09:26 PM
