tweeter problem
Old May 1, 2006 | 04:34 PM
sundeep's Avatar
tweeter problem
I installed some new tweeters this morning. They worked fine for a bit, but then one had some static for a few seconds and stopped working. I then took it out to see if i could find someting wrong, and it was really hot to touch. Is the tweeter messed up? could it had been incorrect wiring? thank you
Old May 1, 2006 | 06:18 PM
glott's Avatar
proally blown
Old May 1, 2006 | 09:39 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Maybe you crossed the + and - and blew it or it grounded out somehow
Old May 29, 2006 | 12:25 AM
miltcharlie's Avatar
Lord Ubber
The + - is'nt the real issue. You would only have a phase problem.
Were the tweets crossed-over?
Stock or aftermarkek H/U?
high or low quality tweets?
what is tweet pwr rating?
What is H/U or amp pwr rating?
Coke or Pepsi?
So many questions and only one answer.
Good luck!
Old May 29, 2006 | 04:38 AM
stic2it's Avatar
Sorry to highjack but whats the lifespan on a pair of tweeters...my tweeters lasted one week...jl xr
Old May 31, 2006 | 12:36 AM
vidgamer's Avatar
To expand on one of the things miltcharlie said, if you put aftermarket tweeters in the stock locations, you need to be sure to wire some sort of crossover into the circuit, else it'll play some lower frequencies into it and that could blow it. There is a mild crossover in the stock amp, but it's probably not enough. (Elduderino includes capacitors with his tweets to perform that function.)
Old May 31, 2006 | 04:52 AM
Lord Ubber
Yeah! What he said.
When I first replaced my factory tweets before I did a major overhaul. I did use the xover that came with the tweets and never had a prob.
So that is good advise and pretty much on the money.
Sorry I did'nt say all this before.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
