TSX tweeter install questions...
Old Sep 28, 2006 | 01:16 PM
supraken's Avatar
What did you guys do when you replaced the tweeter? Did you just strip the wires, or is there a way to use the existing connector? I'm trying not to cut the wires if I don't have to....
Also, when hooking up to an external amp, how did you guys connect the crossovers? I have separate high pass and low pass filters for the 6.5" drivers and the tweeters, how should I connect them? should I connect them to the same two channels of the amp?
Old Sep 28, 2006 | 03:09 PM
jlukja's Avatar
elduderino's avincar tweeters came with t-taps. You just snap them onto the wires just below the connector. This way, you can remove them and restore the original tweeter on the same connector anytime you want.
Old Sep 28, 2006 | 03:32 PM
supraken's Avatar
Do you have any pics of this T-tap? Where can I get this, without having to get them shipped from Ken, if he even sells them at all?
Old Sep 28, 2006 | 04:28 PM
Reach's Avatar
You can get these at radioshack man. Just ask the nerd there, but they are in one of the pullout bins and cost about $2 for a box of 10.
T-taps.. that's too easy. I can't believe when I did mine I cut off the connectors, stripped and soldered them. That took me forever to get right cause I had to be super careful not to burn the car and still make good connections, not to mention there is like zero room to move there thanks to the placement and angle of winshield. grrrr. </rant>
Old Sep 28, 2006 | 05:34 PM
elduderino's Avatar
VP Electricity
Yes, the wires are too short to work with.
T-taps should be available at any auto parts store too. Get 3M T-Tap brand.
Old Sep 28, 2006 | 09:02 PM
supraken's Avatar
Ahh ok, seached for some pics of the 3M T-taps and finally can understand what it's supposed to do. That's a great help, thanks!
by the way, is there a particular size that I should get??
Old Sep 28, 2006 | 09:04 PM
supraken's Avatar
Also, the other question I have....... How did you guys connect the tweeter, crossovers, drivers? Are they all going to be fed through the same two channels?
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
nuldabz
Sep 3, 2015 05:49 PM
