tsx constant power wire not working now
Old May 5, 2005 | 01:51 PM
palidanx's Avatar
honk not beep
i recently hooked up my parrot kit to the constant power wire in the tsx and now i'm getting no power from it.. I tested the parrot car kit with the remote wire, and it turns on. Anyone have some suggestions on diagnosing this?
wire a10 is the constant power.
thanks!
Old May 5, 2005 | 02:00 PM
Jonesi's Avatar
Check your connections...Try A9..
What the heck is a parrot kit ??!!!
Old May 5, 2005 | 03:20 PM
elduderino's Avatar
VP Electricity
Well, you lost a fuse somewhere or your tap is bad. DOes the OEM amp no longer work? If it DOES work, it's your connection. IF it doesn't work, it's the circuit for the amp power that's fused...i dunno, I'll look in Helms if you want.
Old May 5, 2005 | 03:53 PM
palidanx's Avatar
honk not beep
i removed the oem amp a whiel ago and put in an aftermarket. The parrot kit is a bluetooth car kit (sorry for the lack of explanation). I have the helms also...
oh yea eldud, you have a pm from me =)
Old May 5, 2005 | 06:58 PM
Jonesi's Avatar
I think what he was asking is your current amp functioning properly.. If it is working fine then it's a connection that is your problem..
Old May 6, 2005 | 10:27 AM
TSX559's Avatar
i use A10 for constant power and its working for me. might just be a connection problem or fuse.
Old May 6, 2005 | 10:48 AM
palidanx's Avatar
honk not beep
yea.. just checked fuse #5.. its broken... thanks guys =)
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
acurajj
Sep 19, 2015 03:47 PM
Phambam12
Sep 6, 2015 06:57 PM
