TSX Audio Installation Kit
Hi Guys;
Quick question... I am looking to install a DVD player in the CD storage compartment. It is an alpine din sized unit and I was wondering if I were to purchase the factory audio bezel kit (which i believe is meant for the oem mp3 or dvd drive) if it would fit properly. Basically I am wondering if that bezel is din sized?
example
http://cgi.ebay.com/ebaymotors/Acura...mZ280041628201
example
I know pretty much nothing abou this and just get confused when i read about it but I am basically looking to do the same thing and I ordered one of those kits. Read on a forum somewhere that it is a tiny bit wider but fits much better than without it. Here are a couple links I found that might help.
https://acurazine.com/forums/showthr...00#post5391900
http://www..com/forums/showthread.ph...0&page=1&pp=15
Originally Posted by arrush
i dont want you ripping a car apart, just dont want to spend a $100 if it's no good... lets hold on and see if anyone else knows...
You might also want to ask about the depth of the unit and mounting holes of the brackets. The OEM stereo accessory is an inch or two shallower than aftermarket radios are, and I have no idea if the holes from the OEM mounting kit will fit an aftermarket stereo without modification.
Originally Posted by Spoon
The brackets will fit a DIN unit, but the bezel opening is wider than a DIN space. There is a 10mm gap to the left and right sides and ~2mm gap above and below.
Originally Posted by arch
I fit a DIN dvd unit in my compartment. You have to cut one side. Let me take pics tomorrow of the work. Door still functions and latches properly. Concealment is great and worth the surgery.
I actually used this kit and made a cover out of plexi-glass and painted it black. The mount works great, but I got tired of the space on the outside so I made the cover. I'll try and get a pic up soon.
cycdaniel
Dec 17, 2019 10:58 AM
InFaMouSLink
Oct 27, 2015 06:51 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
nuldabz
Sep 3, 2015 05:49 PM
