System replacement w/ Factory Nav
Old Feb 29, 2004 | 11:12 PM
gmfreed's Avatar
Has anyone changed their speakers and amps with the Factory Nav. Does it keep the Nav voice?...Does voice activation still work?
Old Mar 1, 2004 | 08:48 AM
Gpump's Avatar
You want me to break it?
Re: System replacement w/ Factory Nav
So long as take the signal from the headunit the nav voice still comes out the same way, only be careful with the sensitivity settings on your amp- I'd sugget you start low/soft and then increase it - I started a little high and that lady's voice about deafened me the first time I used it - voice activation is totally separate, not affected, works fine.
Or, if you go the line out converter route, as long as you get a signal from the driver's speaker too (not sure if it's the 6.5 or the tweeter - maybe someone else knows) it should work - I bypassed the amp and didn't have to think about it after that.
Old Mar 1, 2004 | 10:07 PM
gmfreed's Avatar
Cool thanks. that helped alot. I don't have to use a line out converter, with the amps i am using i can just extend the outputs of the radio and put RCA ends on them and plug them in...it will work great that way.
cycdaniel
Dec 17, 2019 10:58 AM
TLDude876
Dec 28, 2016 03:18 PM
scionxb3003
Oct 2, 2015 05:50 PM
Gianni Formica
Sep 7, 2015 08:28 PM
asahrts
Sep 4, 2015 05:55 PM
