System replacement w/ Factory Nav
Has anyone changed their speakers and amps with the Factory Nav. Does it keep the Nav voice?...Does voice activation still work?
You want me to break it?
Re: System replacement w/ Factory Nav
Or, if you go the line out converter route, as long as you get a signal from the driver's speaker too (not sure if it's the 6.5 or the tweeter - maybe someone else knows) it should work - I bypassed the amp and didn't have to think about it after that.
Cool thanks. that helped alot. I don't have to use a line out converter, with the amps i am using i can just extend the outputs of the radio and put RCA ends on them and plug them in...it will work great that way.
cycdaniel
12-17-2019 10:58 AM
TLDude876
12-28-2016 03:18 PM
Gianni Formica
09-07-2015 08:28 PM
asahrts
09-04-2015 05:55 PM
