System complete!
Old Mar 4, 2009 | 12:39 AM
UNeeKLiNG's Avatar
System complete!
- Custom climate control bezel with single din slot (with the help of LIPSTUH)
- Red LED's
- Alpine W-505
- Alpine Blackbird PMB 200
- PXA H701 (multimedia manager)
- RUX C701
- Apline PDX-5
- Infinity Kappa Perfect Front Components
- Infinity Kappa 6x9
- Infinity Basslink (Might upgrade to JL W3 or W6 in the future)
Yes that is Jessica Alba's Ass
RED LEd's
Just ordered a new sunroof control..need to replace cover cause I used too much acetone you can barely see the dimmer light from this angle
Old Mar 4, 2009 | 12:40 AM
UNeeKLiNG's Avatar
UNCALD4: any recommendations on tuning for the bass frequencies? I'm having a hard time setting the crossover function for the sub in the PXA. Thanks.
Old Mar 4, 2009 | 12:55 AM
so cal eddie's Avatar
Why do you need the 701 controller seperate? It looks really nice molded though.
Old Mar 4, 2009 | 01:02 AM
Oops. Didnt finish. Can the 505 control the 701? I thought it could anyway. I could help you set up your system if you want. Im in chino hills. Ive been installing for more than 10 years now.
Old Mar 4, 2009 | 01:08 AM
UNeeKLiNG's Avatar
yea you can control the the pxa from the 505 i just wanted the controller for accent
and yea that would be awesome! i would love some help.
Old Mar 4, 2009 | 11:27 AM
uncald4's Avatar
Former Sponsor
Can you shut the BassLink's crossover off? If so you should set your PXA crossover at 80hz for the sub.
Old Mar 4, 2009 | 12:10 PM
UNeeKLiNG's Avatar
I will check on the basslink.
The PXA has a HPF and a LPF crossover for the sub. Which should I set to 80hz and what for the other one? Thanks Uncald4.
Old Mar 4, 2009 | 05:42 PM
saltyone's Avatar
SNAFU
Very nice. I love the W-505 and the Alpine processor is a sweet piece of gear. I'm all about accent pieces, so like you, I would have installed the RUX also. When you're able, I would replace the sub with a custom built enclosure...JMO. Congrats!
Old Mar 4, 2009 | 06:19 PM
BlueAc's Avatar
Acura drove me away too..
That looks very good... I would ditch the basslink and do a W3!
Old Mar 4, 2009 | 07:11 PM
bdeitemeyer's Avatar
Brad
Looks nice.
Question: I'm not familiar with the CL-S accessories, so are your climate control knobs stock? If not, where can I find them?
Old Mar 5, 2009 | 11:36 AM
mitch14's Avatar
CL in lawnmower status
i would ditch the basslink and get a w6
if you just wanna add some bass into your system a w3v3 will suffice, but not if you're a basshead
I have two 12" W3v3's in a custom sealed enclosure, and it's right on the cusp of enough bass or just not enough bass. But i don't wanna spend the extra money to get brand new w6's so i guess i'll stick with them.
good work on the system tho and for the quality and cleanlyness of the work upfront, i think you need some custom trunk work in the back, just my
Old Mar 5, 2009 | 12:02 PM
uncald4's Avatar
Former Sponsor
The High Pass Filter should be off for the sub. But the LPF should be @ 80hz.
Old Mar 5, 2009 | 12:30 PM
UNeeKLiNG's Avatar
awesome thanks again uncald4!!!
Originally Posted by bdeitemeyer
Looks nice.
These are custom made knobs by someone a few years ago. I dont' think they sell them anymore.
My whole goal was to maximize trunk space so I don' tthink I'll be needing any fancy custom work. I will be upgrading to a W3/6 inthe future. I'm not a basshead. I'm all about a clean sounding system.
Old Mar 5, 2009 | 12:48 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Looks great man
Old Mar 5, 2009 | 12:54 PM
UNeeKLiNG's Avatar
Looks great man
thanks!
One more thing, what if I can't shut off the crossover for the basslink? what should I set the crossover on the basslink to? and what about the LPF on the pXA?
Old Mar 5, 2009 | 01:04 PM
mitch14's Avatar
...My whole goal was to maximize trunk space so I don' tthink I'll be needing any fancy custom work. I will be upgrading to a W3/6 inthe future. I'm not a basshead. I'm all about a clean sounding system.
^just get a w3v3 then, should be good enough for you.
And as far as custom trunk enclosures etc, most of the ones i've seen on here actually help to maximize trunk space.
Like sub enclosures being mounted in the back corners of the trunk, fiberglassed to fill up the space exactly.
Or false floor setups, which take away the spare but leave you with the same size trunk minus a few inches in depth (that's what i'm trying to finish soon).
and i've seen many different setups from uncald4, all of them taking up less space than a traditional box IIRC
but it's up to you, and with custom enclosures it can get quite costly, good luck
Old Mar 5, 2009 | 11:53 PM
94Prelude1488's Avatar
2003 Acura 3.2CL Type-S
This is off topic but I'm trying to replace my heated seats and Cruise Control/Sunroof lights to light up blue, what type of bulb did you use? A bulb number or link would be great. Thanks.
Old Mar 6, 2009 | 12:50 AM
dope!'s Avatar
I'M BACK!!!
shit looks clean johnny!
Old Mar 6, 2009 | 03:17 AM
kay_xrs's Avatar
That is a clean set up you have there.
Old Mar 6, 2009 | 11:41 AM
UNeeKLiNG's Avatar
I used 5mm led's, you can find them on ebay and it comes in a package of 50, 100 or more depends. Doesn't really matter what the mcd is, 5000 mcd and above should be good enough.
Thanks Georgie!
Old Mar 9, 2009 | 11:50 AM
Thanks for the help.
Old Mar 11, 2009 | 05:51 PM
madermu's Avatar
Quick question.....
is that one 12 you have?
if so, how does that sound.....i'm debating on 1 12 or 2......i have an '08 TL
and i just purchase 1 JL 12w3 with a jl 400 RMS amp.....
i just don't know if i will need two or not?
thanks for the help.
Old Mar 13, 2009 | 07:11 AM
eggyhustles's Avatar
try the w5 shallow mount then
Old Mar 27, 2009 | 05:18 PM
susu's Avatar
wow, the Alpine navi looks nice installed! I took a look at it in stores but didnt really like it. But it looks great installed onto your car thou!
Old Apr 25, 2009 | 11:11 PM
wildmonk69's Avatar
awesome
Feb 25, 2020 09:57 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
Sep 17, 2015 09:01 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:09 PM
