System complete!
- Custom climate control bezel with single din slot (with the help of LIPSTUH)
- Red LED's - Alpine W-505 - Alpine Blackbird PMB 200 - PXA H701 (multimedia manager) - RUX C701 - Apline PDX-5 - Infinity Kappa Perfect Front Components - Infinity Kappa 6x9 - Infinity Basslink (Might upgrade to JL W3 or W6 in the future) http://i289.photobucket.com/albums/l...L/IMG_0389.jpg http://i289.photobucket.com/albums/l...L/IMG_0390.jpg http://i289.photobucket.com/albums/l...L/IMG_0391.jpg Yes that is Jessica Alba's Ass :drool: http://i289.photobucket.com/albums/l...L/IMG_0393.jpg http://i289.photobucket.com/albums/l...L/IMG_0097.jpg RED LEd's http://img87.imageshack.us/img87/932/img9584jt0.jpg http://img233.imageshack.us/img233/3...581copykw8.jpg http://img158.imageshack.us/img158/1640/img9582bi5.jpg Just ordered a new sunroof control..need to replace cover cause I used too much acetone :tomato: you can barely see the dimmer light from this angle http://img233.imageshack.us/img233/2448/img9565el1.jpg |
UNCALD4: any recommendations on tuning for the bass frequencies? I'm having a hard time setting the crossover function for the sub in the PXA. Thanks.
Why do you need the 701 controller seperate? It looks really nice molded though.
Oops. Didnt finish. Can the 505 control the 701? I thought it could anyway. I could help you set up your system if you want. Im in chino hills. Ive been installing for more than 10 years now.
Originally Posted by so cal eddie
(Post 10596858)
and yea that would be awesome! i would love some help. |
Originally Posted by UNeeKLiNG
(Post 10596866)
yea you can control the the pxa from the 505 i just wanted the controller for accent :toocool:
Originally Posted by uncald4
(Post 10598017)
Can you shut the BassLink's crossover off? If so you should set your PXA crossover at 80hz for the sub.
The PXA has a HPF and a LPF crossover for the sub. Which should I set to 80hz and what for the other one? Thanks Uncald4. |
Very nice. I love the W-505 and the Alpine processor is a sweet piece of gear. I'm all about accent pieces, so like you, I would have installed the RUX also. When you're able, I would replace the sub with a custom built enclosure...JMO. Congrats!
That looks very good... I would ditch the basslink and do a W3!
Looks nice.
Question: I'm not familiar with the CL-S accessories, so are your climate control knobs stock? If not, where can I find them? |
i would ditch the basslink and get a w6
if you just wanna add some bass into your system a w3v3 will suffice, but not if you're a basshead I have two 12" W3v3's in a custom sealed enclosure, and it's right on the cusp of enough bass or just not enough bass. But i don't wanna spend the extra money to get brand new w6's so i guess i'll stick with them. good work on the system tho:thumbsup: and for the quality and cleanlyness of the work upfront, i think you need some custom trunk work in the back, just my :2cents: |
(Post 10598195)
I will check on the basslink.
(Post 10603187)
The High Pass Filter should be off for the sub. But the LPF should be @ 80hz.
Originally Posted by bdeitemeyer
(Post 10600229)
Looks nice.
Originally Posted by mitch14
(Post 10603046)
Looks great man
(Post 10603422)
Looks great man
(Post 10603187)
(Post 10603339)
...My whole goal was to maximize trunk space so I don' tthink I'll be needing any fancy custom work. I will be upgrading to a W3/6 inthe future. I'm not a basshead. I'm all about a clean sounding system.
And as far as custom trunk enclosures etc, most of the ones i've seen on here actually help to maximize trunk space. Like sub enclosures being mounted in the back corners of the trunk, fiberglassed to fill up the space exactly. Or false floor setups, which take away the spare but leave you with the same size trunk minus a few inches in depth (that's what i'm trying to finish soon). and i've seen many different setups from uncald4, all of them taking up less space than a traditional box IIRC but it's up to you, and with custom enclosures it can get quite costly, good luck |
This is off topic but I'm trying to replace my heated seats and Cruise Control/Sunroof lights to light up blue, what type of bulb did you use? A bulb number or link would be great. Thanks.
shit looks clean johnny!
That is a clean set up you have there.
Originally Posted by 94Prelude1488
(Post 10606324)
Originally Posted by dope!
(Post 10606473)
Thanks for the help.
Quick question.....
is that one 12 you have?
if so, how does that sound.....i'm debating on 1 12 or 2......i have an '08 TL and i just purchase 1 JL 12w3 with a jl 400 RMS amp..... i just don't know if i will need two or not? thanks for the help. |
(Post 10603339)
awesome thanks again uncald4!!!:thumbsup:
These are custom made knobs by someone a few years ago. I dont' think they sell them anymore. My whole goal was to maximize trunk space so I don' tthink I'll be needing any fancy custom work. I will be upgrading to a W3/6 inthe future. I'm not a basshead. I'm all about a clean sounding system. |
wow, the Alpine navi looks nice installed! I took a look at it in stores but didnt really like it. But it looks great installed onto your car thou!
awesome
