MISC: switch wiring help.
Old Oct 29, 2012 | 02:01 PM
potmilkz's Avatar
switch wiring help.
anyone know how to wire this up..
i know + and -
but what is NC1 and NO1 also what is c1.. how do i wire this switch to work properly as it should?
Old Nov 8, 2012 | 11:09 AM
Randy99CL's Avatar
NC stands for "Normally Closed" and NO is "Normally Open." Is this a momentary-action pushbutton switch, like for a fog light relay? Whatever is wired to NC will be on until the switch is pushed, then it will go off. Whatever is wired to the NO will be off until the switch is pushed, then go on. For a light relay you wire it to NO.
Old Nov 9, 2012 | 08:03 AM
Randy99CL's Avatar
As I look at this again I realize I should explain more. As drawn, the diagram shows the circuit is complete through C1 to NC1. When you push the button the circuit will be complete from C1 to NO1. So if this switch is to control a relay you connect +12 (Hot) wire to C1 and NO1 goes to the coil in the relay. The X in a circle represents the light bulb in the switch and you wire that to the secondary contacts in the relay so that it lights when the relay is "on". Make sense? Happy to help, any more questions just ask.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
eastcoastguy
Sep 23, 2015 06:29 AM
