sub questions? qucik help
Old Dec 13, 2004 | 05:10 PM
Marc S's Avatar
a buddy of mine wants to either run 1 15" or 2 12's.... i know alot rides on brands and amps and alla that, but overall what would sound better? he wants to keep it on the cheaper side... no pyramid subs, but somethin cheap... what are some brands out there that are cheaper and will hold up pretty good?? thanks in advance
Old Dec 13, 2004 | 05:22 PM
BEETROOT's Avatar
Yeehaw
my recommendation is always to get a better quality sub rather than a bigger sub or more subs. so if your buddy wants to spend 300 bucks, get the best 12 for that price instead of 2 lesser quality 12's, or a lesser quality 15.
solobaric l5 dvc is on sale for 150 at crutchfield... pretty good deal if he has an amp to run it...
http://www.crutchfield.com/S-ZyRiyqC...0&I=2062S12L52
do you know how much he wants to spend?
Old Dec 13, 2004 | 06:09 PM
suXor's Avatar
Still trolling
smaller subs generally mean cleaner bass. I run two Infinity 10's off A bazzoka amp (kinda cheap) but it sounds great.
Old Dec 14, 2004 | 03:57 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Get boston acoustic sealed bandpass boxes....they knock and the sound is uber clean
Old Dec 14, 2004 | 04:01 PM
Red-CL's Avatar
Doin' da crack shuffle
That depends on how loud you wanna go and how you amp is set up.
The bigger the sub, the deeper he bass.
Get the 15............
Old Dec 14, 2004 | 04:56 PM
rezurex's Avatar
drop em like its hot
i run 1 alpine 12" type S sub with type II Q logic box... runs off profile 600 msx amp. sound is very clean and since i have no dynamat for now i keep the amp at a low level.
the boom i get from just that one sub is more than enough IMO, the whole cars shakes and i think more subs would just be overkill IMO
all in all, its your ride if you want to go big on the bass its all you
Old Dec 14, 2004 | 08:49 PM
Hobo's Avatar
Flap.
bandpass is designed to fudge a little accuracy for more spl..
id go with 2 12's over 1 15...
2(pi*6^2) = 226.08
pi*7.5^2 = 176.625
more surface area and more accurate sound...
i would go with 3 10's over the 2 12's though which is what i was running in my first gen cl.
3(pi*5^2) = 235.5
Old Dec 14, 2004 | 11:08 PM
NewAgePirate's Avatar
"L-I-V-I-N"
2 12's over a 15 any day. A 15 will go lower but 2 12's are going to hit harder. One 15 is going to sound way muddier. Bandpass is BS, BTW and for the reasons listed above. Though this all requires you to set it up right. Research. Get the right size amp and make sure it is set up and wired correctly by whoever does your install. Most importantly, and soooooo many people fudge this and kill their systems, the box is CRUCIAL. It has to have the right air volume for your particular speakers, too small or too big and your sound is fucked.
Old Dec 15, 2004 | 05:42 PM
clcars's Avatar
2 12s is what he needs. 15s are old school and will produce a real deep boomy base. 12s are a bit more of an all around speaker.
Old Dec 15, 2004 | 07:54 PM
ou sig's Avatar
Boomer SOONER
I agree, you can even get 1 10 or 12 if you get a good one like JL W7, but my 2 12's are all I would ever want...and all my trunk wants!
Old Dec 22, 2004 | 03:55 PM
C The "S"'s Avatar
Get 2 JL 12W0, build a good box and add some good power and you're good to go. Box design can make a big difference. Go to a JL authorized dealer and they will have a JL reference manual thats shows you what type of sound and performance to expect from certain type(ie ported, sealed) and size(ie. cubic ft) enclosure.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
