Sub amp questions
Old May 27, 2004 | 01:15 PM
steveinathens's Avatar
Sub amp questions
ok, i already have a sub and a box to go with it. now its time to choose an amp.
i've narrowed it down to two models: Alpine MRD-M501 or JL Audio 250/1
any suggestions?
also, will i need a Capacitor for this install? or should i be ok without it in this case.
Old May 27, 2004 | 01:23 PM
shawhite's Avatar
i guess it depends on what speaker you are using.... i would say that you will be safe without a cap...
Old May 27, 2004 | 01:26 PM
Infinity Kappa Perfect 10
Old May 27, 2004 | 01:52 PM
shawhite's Avatar
i would say go with which ever one you can get cheapest... they are both going to give you about the same power... but the alpine will double if you have a 2ohm load...
Old May 27, 2004 | 02:05 PM
i see. any major difference in SQ between the two?
Old May 27, 2004 | 02:26 PM
AcuraX2's Avatar
If you are going to run your sub at 2 ohms, I would go with the Alpine. Extra 3 db of output is never bad. Both amps are going to give you good quality. For bass amps, it will be hard to tell a difference at the same wattage.
Old May 28, 2004 | 07:42 PM
ok, i'm a little unclear on this. its a 4 ohm speaker, just 1 of them, so connected to the Alpine M501 would it not be running at 4 ohms? does tapping into the factory wires have anything to do with it?
thanks for all the help....
Old May 28, 2004 | 08:38 PM
999999's Avatar
Yes, 4 ohms......
as long as it is a single voice coil sub. DVC can change things.
If the prices are similar, go with the JL. They are not over-rated like Alpine does.
Better yet, if you have some time, wait for a Zapco Studio 300x to come up on Ebay and pay $300 or less. 460 super-clean watts into a sub and a nice crossover.
The Infinity Kappa is fairly efficient, so the JL should be enough. It also is nice in that it is designed for a very small sealed box.
Old May 28, 2004 | 09:01 PM
oh yes, its single voice coil...
thanks
Old May 29, 2004 | 07:28 AM
AcuraX2's Avatar
What do you mean by this. Are you saying Alpine overates their amps or that Alpine is overated? Either statement is not true. Alpine is one of the first companies to adopt the new system of measuring power, (CEA-2006). As for Alpine being overated, that is a matter of opinion.
Old May 29, 2004 | 10:34 AM
999999's Avatar
So, Alpine is starting to come clean......
Just looked at the Alpine site and see that they started this standard in 2004.
Looky here at the specs for the 9821 head unit (copied right from Alpine1.com):
Key Features
CEA-2006 Power Ratings
16W x 4 (4ohm@14.4V 1% THD+N)
S/N 80dBA (Ref: 1W into 4ohm)
What is the CEA-2006 Specification?
• 45W MAX x 4 High Power Amplifier
• Bass Engine®
Notice the drop form 45W advertised to 16W measured? This is a unit that they were selling at 45 watts.
Looking at the specs for the amp in question here, the M501, I see that the measured signal to noise ratio is 60! That is God-awful. Don't put anything in your system under 80. Mine are all 95 to 105.
Alpine used to make all good stuff. I had a head unit about twenty years back when it was all made in Japan, made for performance and not marketed nearly as much.
Old May 29, 2004 | 12:12 PM
AcuraX2's Avatar
I will agree with you on the new stuff. Alpine is now a mass market brand and not the cream of the crop they once were.
As for the inflated head unit specs, name a company that does not do this. Most people will be running after market amps and the head unit power is irrelevant. However, the new internal amps of the Alpine head units provide some of the best head unit power out. That is why you need to hook them directly to the battery.
Anyway, off topic of the post, sorry. For a bass amp, go with either one but, I too personally would go with the JL.
Old May 29, 2004 | 12:51 PM
999999's Avatar
Sadly, A/D/S is almost going down that same path....
The stuff is mostly going downhill. I wouldn't buy the new amps. Mine is 17 years old.
The A/D/S speakers I run now are not as good as the old 320is.
The sub delivers good sound quality for me, though.
Old May 29, 2004 | 01:00 PM
thats a good point you make 9'er
the signal to noise ratio of the JL 250/1 is 95 as compared to the Alpine's 60
very interesting...
Old May 29, 2004 | 07:10 PM
ok, so i got the JL amp today. cheaper, more power at 12V, and the S/N ratio difference were the selling points for me.
when tapping the line to the factory amp for input, shall i set the amp to high or low Input Voltage?
Old May 29, 2004 | 08:19 PM
VTEC11's Avatar
You can try them both, but I would think it needs the LOW VOLTAGE input since your using a preamp signal.
Old May 29, 2004 | 08:26 PM
that's what i thought, just wanted a second opinion...
thanks
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
