Stock Bose speaker system
Old May 25, 2004 | 01:51 PM
Brian_C6's Avatar
is it a common ground system?
Brian
Old Jun 1, 2004 | 04:36 AM
ynot82's Avatar
what year?
Old Jun 1, 2004 | 09:29 AM
Brian_C6's Avatar
'02. TL-S. w/ Bose
Old Jun 1, 2004 | 11:32 PM
ynot82's Avatar
no the front and rear 6.5 are 4ohms and the 9" subs about 6 ohms. the factory amp is behind the deck. if deck is change to an after market you will loose the subs but the factory speaker will work fine.
Old Jun 2, 2004 | 10:26 AM
jg123's Avatar
I thought the sub was 1 ohm. I haven't measured it, but that's what others here have said in the past.
Old Jun 3, 2004 | 01:31 AM
ynot82's Avatar
i ohm the 9" subs with a DMM and it measure 6 ohms?
Old Jun 3, 2004 | 08:33 AM
VTEC11's Avatar
That might be because DMM's use a fixed frequency to measure ohms. Some are fixed at say 60hz. You need a true RMS meter such as certain fluke models. But I'm not arguing that its 1ohm or 6ohm, I don't know.
Old Jun 7, 2004 | 11:38 AM
ynot82's Avatar
i used a fluke!
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
alan_rich
Sep 7, 2015 11:08 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
