stock amp for tsx.
Old Apr 22, 2007 | 08:49 PM
daicacharco's Avatar
stock amp for tsx.
hey, i was wondering if i add aftermarket components and amp. can i take out the stock amp? will anything happen after i take out the stock amp ?
thank you.
Old Apr 23, 2007 | 12:45 PM
Castles_Saloon's Avatar
I had wondered the same, but after looking at the main sticky, https://acurazine.com/forums/audio-video-electronics-navigation-22/%2A%2Aaudio-video-diy-info-faq-all-models-%2A%2A-299065/ some wiring diagrams can be found.
http://www.shinzu.com/tsx/images/repair/tsxaudio.jpg
like eldurino mentioned, b7, is the remote turn on. both the h/u, amp and antenna amp share this. removing the stock amp shouldn't be an issue.
read mercman's 'bypassing the amp' in the sticky. balanced outputs should be cared for.
good luck
Old Apr 23, 2007 | 12:59 PM
Gpump's Avatar
You want me to break it?
I did it a few years ago - works just fine. I also ran rockford fosgate speaker wire throughout which was more of a pain in the butt to do. You shouldn't hurt the radio, just gotta run speaker wire back up to the center console. Disclaimer - my navi system did suffer from the tsb issue of the upper clock display going dark, but the dealership didn't hassle me about it and it should not have been possible for the modification to have caused this.
Old Apr 23, 2007 | 01:02 PM
mercman's Avatar
You will disconnect the stock amp (remove the two plugs) to connect the new amp. It is up to you if you want to physically remove it. I have mine out now so I can do some tests, but it is usually in working as a mounting point for one of the front speaker xovers (also so I don’t lose it).
See my post on bypassing the factory amp for the correct wiring and before you decide on an amp (only a few will work correctly with the TSX HU).
jeff
Old Apr 23, 2007 | 02:50 PM
alright. thanks guys.
Old Apr 23, 2007 | 03:55 PM
Rapmaster0's Avatar
jeff
Would a audiobahn a4004t work?
Old Apr 23, 2007 | 04:42 PM
Gpump's Avatar
See my post on bypassing the factory amp for the correct wiring and before you decide on an amp (only a few will work correctly with the TSX HU). jeff
I just cut the RCA level pre outs, spliced them into some decent RCA cables and ran them to my trunk = any 4 channel amp should work (assuming you don't mind either losing the 6X9's or adding a subwoofer amp to your setup).
I know the signals to the 6X9's were low frequency only but I can't remember the cutoff - regardless, my type of set up should work for just about any 4 channel amp.
Old Apr 23, 2007 | 06:16 PM
Gpump's Avatar
Nevermind, just saw your detailed post. I'm pretty sure my Kenwood amp (10 years old) doesn't have differential inputs. I only get a pop when I have the car off and am listening to the radio then start the car. Alternator whine is only audible at volume levels that I will never use anyway (approximately 2-3). Anyway, nice write up.
Old Apr 23, 2007 | 10:54 PM
mercman's Avatar
You will have problems with the 4004 since it uses unbalanced (coaxial) inputs. This forces one side of the HU balanced output to ground (shorting ½ of each channels output). Doing this can create all sorts of foul sounds from the HU line drivers. This also defeats all of the noise rejection gains of a balanced line. If you already have the 4004 you must use a balanced to unbalanced adapter (BALUN) on each channel just before the power amp. I have not found any off the shelf devices to do this for car audio. Most are very expensive hi end home audio devices.
One could be built for the car but it is best to go with an amp already equipped with balanced inputs.
jeff
Old Apr 24, 2007 | 02:56 AM
Rapmaster0's Avatar
How do you determine what amp uses unbalanced or balanced inputs?
Old Apr 24, 2007 | 03:18 AM
an amp's specs should state balanced or not. if balanced inputs are not mentioned, then its likely not a balanced input and is a single ended input.
for example....
read the input description in the link
http://mobile.jlaudio.com/products_amps.php?amp_id=254
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
Specmiata82
Sep 30, 2015 10:04 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
