SteveStMS - Pls help with Video-NAV kit
Old Nov 17, 2001 | 08:56 PM
yee's Avatar
yee
I'm working on the kit and I've complete soldering the RGB1.
I'm now trying to connect my 4PDT relay. But when I look behind the NAV, I see 4 plugs,
a 1-pin, an 8-pin, a 12-pin, and a 16-pin plugs. and on each of them, there are 1 wire, 8 wires, 7 wires and 9 wires connected to them respectively.
I can't seem to locate the 20-pin which you've describe.
How do you know which is Pin-1, Pin-2 & Pin-10 (power connection for the RGB1 to the NAV)?
and finally, which are the 4 wires for the video signal to the NAV, would the 4 wire (green, white, red, black) be from the same plug? cuz every one of them have a green wire... AHHH!!!!
THANKS!!!
Old Nov 17, 2001 | 09:03 PM
kensteele's Avatar
Dude, here you go
Personally, I would use the Navi connectors found in the trunk area instead of the one's behind the Navi in the dash. Really, you need the scematics (found in Helms manual) before you start cutting.
Old Nov 18, 2001 | 01:44 AM
SteveStMS's Avatar
The White, Red, Yellow and Green wires you need are found on the 12-pin plug. It's the middle plug on the back of the navigation computer in the trunk.
Old Nov 18, 2001 | 06:51 AM
yee's Avatar
yee
THANK YOU!!!
SteveStMS, Kensteele, you two are the man!
another question from the clueless guy... how or where can I draw power to the decoder from the NAV_DVD player, in another words how can I hook up the orange(constant, black(accessory), blue(ground, can I ground it elsewhere, ie, on the circuit board?)
Old Nov 18, 2001 | 01:01 PM
kensteele's Avatar
My decoder is powered from wires from the fuse box, completely separate from the Navi. It is also grounded from a separate wire that connects to a screw someplace in the chassis that's well grounded.
Old Nov 18, 2001 | 07:44 PM
yee's Avatar
yee
Just wanna celebrate my 'turning to a freak' post here!
Kensteele, so...the blue wire is labeled as 'remote' what exactly is it for? there are two connection to the wire, so I guess I should connect the main one right? thanks.
Old Nov 18, 2001 | 08:52 PM
Mstyle's Avatar
Huh???? Damm I'm gonna start that project soon...
Old Nov 18, 2001 | 08:53 PM
kensteele's Avatar
You lost me. I did the hookup earlier this summer and I don't quite remember. Maybe Steve can help. Seems to me the Decoder blue wire was labeled ACC for accessory.
Old Nov 18, 2001 | 11:56 PM
SteveStMS's Avatar
Power can be picked up from the 1st 8-pin connector. Pin 1 (upper left corner) is constant power for AVC-RGB1 decoder yellow wire. Pin 2 is the accesory power for AVC-RGB1 decoder blue wire and Pin 4 is ground for AVC-RGB1.
Old Nov 19, 2001 | 01:31 AM
yee's Avatar
yee
Steve and Ken man...you guys ever come to S.F. and need a ride...just let me know.
Old Nov 19, 2001 | 03:03 AM
bnaderi's Avatar
yee, how much did you get that part for?
Old Nov 21, 2001 | 12:06 AM
yee's Avatar
yee
the RGB1 costed me $150...
+ ~$20 of wires and switch...
Steve, Ken, could you guys check and see if I've the stuff soldered properly...I posted it on the video to navi thread on top.
also...could you tell me which color wire runs -'ve current? the blue one on the RGB box is +'ve.
thanks. E
Old Nov 23, 2001 | 08:51 PM
zyylo's Avatar
Hey YEE
I got the TL Electrical diagram book...Email me if you want copies of the NAVI wiring set
Tom
zyylo@aol.com
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
