Someone please help me map out the wiring on my system
Old Sep 8, 2002 | 09:00 PM
plkalra's Avatar
Hello
My question is somewhat long. I have my whole system now, but I don't know what wiring to use. I mean I'm gonna buy stinger, but where do I run what.
Here's the setup
HU--Panasonic CQ-DVR909u
· 45W x 4 + 5W Center Channel
· Frequency Response (±1dB) DVD-Audio (192kHz sampling): 2Hz - 88kHz, DVD-Video (96kHz sampling): 20Hz - 44kHz CD: 20Hz - 20kHz
Front Speakers--Alpine SPX-177A 6 ½” Components
· Ultra High Quality 2-Way Crossover
· Frequency Response : 35Hz - 35 kHz
· Impedance (Nominal) : 4 ohms
· 60 watts RMS, 240 watts Peak
Rear Speakers--Alpine SPS-1629S 6 ½” Coaxial 2 Way Speakers
· Frequency Response : 40Hz - 25kHz
· Power Handling Capacity (Peak) : 120W
· Power Handling Capacity (RMS) : 30W
Sub--Alpine SWR-1241D 12” Type R
· Frequency Response : 28Hz - 1kHz
· Free Air Resonance (Fs) : 29Hz
· Impedance (Nominal) : 2 ohm + 2 ohm
· Power Handling Capacity (Peak) : 1000W
· Power Handling Capacity (RMS) : 300W
Amp that powers These 5 things--Alpine MRV-F450
MAX Power (at 14.4V,EIAJ)
Bridged 4 ohms : 240W x 2 + 370W x 1
Per channel into 4 ohms : 90W x 4 + 370W x 1
RMS Power (at 12V,20Hz-200Hz)
Bridged 4 ohms : 80W x 2 + 150W x 1
Per channel into 2 ohms : 40W x 4 + 150W x 1
Per channel into 4 ohms : 30W x 4 + 150W x 1
RMS Power (at 14.4V,20Hz-200Hz)
Bridged 4 ohms : 120W x 2 + 200W x 1
Per channel into 2 ohms : 60W x 4 + 200W x 1
Per channel into 4 ohms : 50W x 4 + 200W x 1
Mini Subs under Seats--Alpine SWS-BE45 Bass Engine
· Frequency Response : 20Hz-80Hz
· Resonance Frequency 40Hz
· Force 15lbf(66N) at 50W
· Power Range 25Watts-50Watts(RMS)
Amp that powers the mini subs--Alpine MRP-T406
· Frequency Response : 10-50kHz
· 1 x 240 Watts Max
· 2 x 90 Watts Max
· Built in X-Over
I'm also running one LCD screen but the HU has an input for it
questions...
1. What gauge power and ground should I run, 4?Speaker 12 or 14?
2. I have to run power and ground for both speakers right, what do I have to put at the battery then, a terminal, what is it called? do I need some type of fuse?
3. RCA's, I'm planning on the Hyper series from Stinger, they make a 4 channel type can i run that?...well knowing my one amp is 5 channel..and my other two..how many rca's do I need???
All in all I basically need helping with telling me where to run what wire, what size, battery terminals, distribution blocks, all that etc stuff...if someone can tell me what to run I can appreciate it. ..thanks soo much...
agupta3224
May 23, 2017 08:30 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
SUPRMN84
Oct 7, 2015 09:46 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
agupta3224
Sep 22, 2015 08:08 PM
