SNHOND3 aux problem
Old Oct 23, 2005 | 07:36 PM
jmills115's Avatar
SNHOND3 aux problem
I tried to install the SNHOND3 in my 2004 TSX non -nav. the headunit won't switch from CD with the double click of the CD/AUX button. I think I have searched every thread for help and have tried not only powering off the headunit twice but also thee ignition also. The h/u isn't recognizing the snhond3 even after killing the ignition.
I read in another thread of a bad run of the snhond3 and was curious if anyone else has had this problem in the past few weeks. Thanks for not only whatever answer I get about this but also the very detailed install's that were already alot of help.
Old Oct 23, 2005 | 08:17 PM
palidanx's Avatar
honk not beep
So your snhond3 never worked?
Old Oct 23, 2005 | 08:20 PM
jiggaman's Avatar
I spend 2 much time here
i had snhond3 working intermittently, switched it for the Blitzsafe version and have since had no problems.
Old Oct 23, 2005 | 08:22 PM
jmills115's Avatar
It hasn't worked at all. I already emailed Soundgate to get there opinion. Hopefully I'll hear freom them tommorrow about a replacement. Since they don't respond over the weekend I was hoping I might find an answer to replacing a unit that is DOA
Old Oct 23, 2005 | 08:23 PM
palidanx's Avatar
honk not beep
Yea.. the snhond3 installation is quite straightforward so I doubt you probably did anything to fry it. Perhaps you jsut got bad luck with a doa unit
Old Oct 23, 2005 | 08:30 PM
jiggaman's Avatar
what do you have connected to the Snhond3?
Old Oct 23, 2005 | 08:40 PM
jmills115's Avatar
I connected a Rio Carbon and I tried a Zen Micro.
Old Oct 24, 2005 | 01:41 PM
CJams's Avatar
Guinea Pig
I bet it's a part of the faulty lot.......I think we need to make a faulty parts thread
1. shond3
2. Dc header
3...........
Old Oct 25, 2005 | 10:25 AM
palidanx's Avatar
honk not beep
i actually have a 3 way switcher connected to the snhond 3.
Old Oct 25, 2005 | 09:42 PM
jmills115's Avatar
Talked with Soundgate and they sent a warranty replacement today. Should have it tommorrow.
Old Oct 27, 2005 | 09:55 PM
jmills115's Avatar
Recieved the warranty replacement and had it installed and hooked up up to the Zen Micro within 15 minutes.
Thank you to those of you that responded or posted pictures in another thread. I would have dropped $40-50 to the stereo shop had I not checked here first.
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
