rockford fosgate 3sixty installed/ system pics
whats up guys installed the 3sixty processor the sound is awesome, i did the system myself let me know what you think.
here's the link to the pics
pics of system
pics of system
gistered User
pics of system
pics of system
Sa-weet install! I'm gathering my 'Stuff' for my tsx install--and yours has inspired me to think more creatively with mine! Nice, jptl04! Q for you: did you solder and shrink tube the speaker wires? I'm 10 thumbs if I have to solder. Brandnamez.com has the 3sixty.1 for $220 + ship. Poor communications (no email/tracking) but it did arrive. Again, sweet system.
gistered User
pics of system
pics of system
Originally Posted by DiaBando
How did you get the wire to snake thru on the drivers side chassis? Other doors/dash were a breeze. Kuddos on you workmanship!
gistered User
jptl- I'm just about to install the 3sixty.1. I understand I'm to cut and splice speaker wire to the LF and RF speakers (no rears) sub, and tap into the remote wire of my OEM amp, running to the 3sixty grounded in the trunk. Which plug (20 or 14) do I access off the OEM amp? Which has the 'out to speakers' ? Thanks! looking forward to the sound improvement!
VP Electricity
1 Post
and i did use the signal AFTER the oem amp, to speakers.
As I recall the TL HU has 5 outputs - 4 and a center? They are balanced differential and they are affected by the volume controls on the steering wheel. The only reason to use a 360 or CS in a TL is that those outputs are equalized (unlike the TSX and older TL and CLs).
gistered User
Just a quick correction on wiring the 'B+' connector to the 3sixty-that I haven't seen posted (even on RFs boards): In the 3sixty manual, perhaps earlier printed editions, it states to use a 'switched' 12volt+ source for the B+ power connector--when you should use a CONSTANT 12v+ source. Eliminate the popping.
Ponsey_Scheme
10-23-2015 09:16 PM
pistacio
09-26-2015 09:45 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
